Datasheet LTC2308 (Analog Devices) - 10
DescriptionLow Noise, 500ksps, 8-Channel, 12-Bit ADC
Pages / Page22 / 10 — TIMING DIAGRAM. Voltage Waveforms for SDO Delay Times, tdDO and thDO. …
File Format / SizePDF / 679 Kb
TIMING DIAGRAM. Voltage Waveforms for SDO Delay Times, tdDO and thDO. tWLCLK (SCK Low Time). tWHCLK (SCK High Time)
TIMING DIAGRAM Voltage Waveforms for SDO Delay Times, tdDO and thDO tWLCLK (SCK Low Time) tWHCLK (SCK High Time)
LTC2308
TIMING DIAGRAM Voltage Waveforms for SDO Delay Times, tdDO and thDO tWLCLK (SCK Low Time) tWHCLK (SCK High Time) tHD (Hold Time SDI After SCK
SCK
tSUDI (Setup Time SDI Stable Before SCK
VIL tdDO t t WLCLK tWHCLK hDO VOH SDO SCK VOL tHD 2308 TD01 SDI 2308 TD03 tSUDI
Voltage Waveforms for tdis Voltage Waveforms for ten
CONVST VIH CONVST SDO 90% WAVEFORM 1 (SEE NOTE 1) SDO 2308 TD04 tdis SDO ten WAVEFORM 2 10% (SEE NOTE 2) NOTE 1: WAVEFORM 1 IS FOR AN OUTPUT WITH INTERNAL CONDITIONS SUCH THAT THE OUTPUT IS HIGH UNLESS DISABLED BY THE OUTPUT CONTROL NOTE 2: WAVEFORM 2 IS FOR AN OUTPUT WITH INTERNAL CONDITIONS SUCH THAT THE OUTPUT IS LOW UNLESS DISABLED BY THE OUTPUT CONTROL
Voltage Waveforms for SDO Rise and Fall Times t
2308 TD02
r, tf
V SDO OH VOL tr tf 2308 TD05 2308fc 10 For more information www.linear.com/LTC2308
