Datasheet LTC2360, LTC2361, LTC2362 (Analog Devices) - 5
Description500ksps, 12-Bit Serial ADCs in TSOT-23
Pages / Page20 / 5 — TIMING CHARACTERISTICS. The. denotes the specifi cations which apply over …
File Format / SizePDF / 325 Kb
TIMING CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating temperature
TIMING CHARACTERISTICS The denotes the specifi cations which apply over the full operating temperature
LTC2360
LTC2361
LTC2362
LTC2360/LTC2361/LTC2362
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) LTC2360 LTC2361 LTC2362 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
fSMPL(MAX) Maximum Sampling Frequency (Notes 8, 9) l 100 250 500 kHz fSCK Shift Clock Frequency (Notes 8, 9) l 10 25 50 MHz tSCK Shift Clock Period l 100 40 20 ns tTHROUGHPUT Minimum Throughput Time, tACQ + tCONV l 10 4 2 μs tACQ Acquisition Time l 2 1 0.5 μs tCONV Conversion Time l 8 3 1.5 μs t1 Minimum Positive CONV Pulse Width (Note 8) l 8 3 1.5 μs t2 SCK↑ Setup Time After CONV↓ (Note 8) l 16 16 16 ns t3 SDO Enabled Time After CONV↓ (Notes 8, 9) l 16 16 16 ns t4 SDO Data Valid Access Time After SCK↓ (Notes 8, 9, 10) l 8 8 8 ns t5 SCK Low Time (Note 11) l 40% 40% 40% tSCK t6 SCK High Time (Note 11) l 40% 40% 40% tSCK t7 SDO Data Valid Hold Time After SCK↓ (Notes 8, 9, 10) l 4 4 4 ns t8 SDO Into Hi-Z State Time After CONV↑ (Notes 8, 9) 6 6 6 ns
Note 1:
Note 6:
Linearity, offset and gain specifi cations apply for a single-ended may cause permanent damage to the device. Exposure to any Absolute AIN input with respect to GND. Maximum Rating condition for extended periods may affect device
Note 7:
Typical RMS noise at code transitions. reliability and lifetime.
Note 8:
Guaranteed by characterization. All input signals are specifi ed with
Note 2:
All voltage values are with respect to GND. tr = tf = 2ns (10% to 90% of VDD) and timed from a voltage level of 1.6V.
Note 3:
When pins AIN and VREF are taken below GND or above VDD,
Note 9:
All timing specifi cations given are with a 10pF capacitance load. they will be clamped by internal diodes. These products can handle input With a capacitance load greater than this value, a digital buffer or latch currents greater than 100mA below GND or above VDD without latch-up. must be used.
Note 4:
VDD = OVDD = VREF = 2.35V to 3.6V, fSMPL = fSMPL(MAX) and
Note 10:
The time required for the output to cross the VIH or VIL voltage. fSCK = fSCK(MAX) unless otherwise specifi ed.
Note 11:
Guaranteed by design, not subject to test.
Note 5:
Integral linearity is defi ned as the deviation of a code from a
Note 12:
High temperatures degrade operating lifetimes. Operating lifetime straight line passing through the actual endpoints of the transfer curve. is derated at temperatures greater than 105°C. The deviation is measured from the center of the quantization band. 236012fa 5
