Datasheet LTC2376-16 (Analog Devices) - 16
Description16-Bit, 250ksps, Low Power SAR ADC with 97dB SNR
Pages / Page26 / 16 — APPLICATIONS INFORMATION Normal Mode, Single Device. Figure 13. Using a …
APPLICATIONS INFORMATION Normal Mode, Single Device. Figure 13. Using a Single LTC2376-16 in Normal Mode
APPLICATIONS INFORMATION Normal Mode, Single Device Figure 13 Using a Single LTC2376-16 in Normal Mode
LTC2376-16
Figure 13 shows a single LTC2376-16 operated in normal When CHAIN = 0, the LTC2376-16 operates in normal mode with CHAIN and RDL/SDI tied to ground. With RDL/ mode. In normal mode, RDL/SDI enables or disables the SDI grounded, SDO is enabled and the MSB(D15) of the serial data output pin SDO. If RDL/SDI is high, SDO is in new conversion data is available at the falling edge of high impedance. If RDL/SDI is low, SDO is driven. BUSY. This is the simplest way to operate the LTC2376-16. CONVERT CNV DIGITAL HOST CHAIN BUSY IRQ LTC2376-16 RDL/SDI SDO DATA IN SCK CLK 237616 F13a POWER-DOWN CONVERT POWER-DOWN CONVERT ACQUIRE ACQUIRE CHAIN = 0 RDL/SDI = 0 tCYC tCNVH tCNVL CNV tHOLD tACQ tACQ = tCYC – tHOLD BUSY tCONV t t BUSYLH SCK tSCKH tQUIET SCK 1 2 3 14 15 16 tHSDO tSCKL tDSDOBUSYL tDSDO SDO D15 D14 D13 D1 D0 237616 F13
237616fa 16 For more information www.linear.com/LTC2376-16 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Reference Input Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Board Layout Typical Application Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Reference Input Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Board Layout Package Description Revision History Typical Application Related Parts
