Datasheet LTC2385-16 (Analog Devices)
Description16-Bit, 5Msps SAR ADC
Pages / Page22 / 1 — FEATURES. DESCRIPTION. 5Msps Throughput Rate. No Pipeline Delay, No Cycle …
FEATURES. DESCRIPTION. 5Msps Throughput Rate. No Pipeline Delay, No Cycle Latency. 93.8dB SNR (Typ) at fIN = 1MHz
Datasheet LTC2385-16 Analog Devices
LTC2385-16 16-Bit, 5Msps SAR ADC
FEATURES DESCRIPTION
n
The LTC®2385-16 is a low noise, high speed, 16-bit 5Msps n
successive approximation register (SAR) ADC ideally n
suited for a wide range of applications. The combination n
101dB SFDR (Typ) at fIN = 1MHz
of excellent linearity and wide dynamic range makes the n
Nyquist Sampling Up to 2.5MHz Input
LTC2385-16 ideal for high speed imaging and instru- n Guaranteed 16-Bit, No Missing Codes mentation applications. No-latency operation provides a n ±0.5LSB INL (Max) unique solution for high speed control loop applications. n 8.192VP-P Differential Inputs The very low distortion at high input frequencies enables n 5V and 2.5V Supplies communications applications requiring wide dynamic n Internal 20ppm/°C (Max) Reference range and significant signal bandwidth. n Serial LVDS Interface To support high speed operation while minimizing the n 78mW Power Dissipation number of data lines, the LTC2385-16 features a serial n 32-Pin (5mm × 5mm) QFN Package LVDS digital interface. The LVDS interface has one-lane and two-lane output modes, allowing the user to optimize
the interface data rate for each application. n High Speed Data Acquisition L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners. n Imaging Protected by U.S. Patents, including 7705765, 8232905, 8810443. Other patents are pending. n Communications n Control Loops n Instrumentation n ATE
TYPICAL APPLICATION
5V 2.5V 2.5V
FFT, fSMPL = 5Msps, fIN = 2kHz
0 0.1µF 0.1µF 0.1µF SNR = 94.0dB –20 THD = –117dB SINAD = 93.9dB VDD VDDL OVDD CLK –40 SFDR = 119dB 24.9Ω DCO LVDS IN+ 4.096V –60 DA INTERFACE + 680pF DB 0V –80 4.096V LTC2385-16 –100 – 24.9Ω 680pF TWOLANES 0V TESTPAT AMPLITUDE (dBFS) IN– –120 PD VCM SAMPLE CNV –140 0.1µF CLOCK REFBUF REFGND REFIN GND –160 0.1µF 0 0.5 1 1.5 2 2.5 FREQUENCY (MHz) 10µF 238516 TA01 238516 TA02 238516f For more information www.linear.com/LTC2385-16 1 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Reference Buffer Characteristics Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Package Description Typical Application Related Parts
