Datasheet LTC2389-16 (Analog Devices)
Description16-Bit, 2.5Msps SAR ADC with Pin-Configurable Analog Input Range and 96dB SNR
Pages / Page40 / 1 — Features. Description. 2.5Msps Throughput Rate. ±1LSB INL (Max). …
Features. Description. 2.5Msps Throughput Rate. ±1LSB INL (Max). Guaranteed 16-Bit, No Missing Codes
Datasheet LTC2389-16 Analog Devices
LTC2389-16 16-Bit, 2.5Msps SAR ADC with Pin-Configurable Analog Input Range and 96dB SNR
Features Description
n
The LTC®2389-16 is a low noise, high speed 16-bit n
±1LSB INL (Max)
successive approximation register (SAR) ADC. Operating n
from a single 5V supply, the LTC2389-16 supports pin- n
Pin-Configurable Analog Input Range:
configurable fully differential (±4.096V), pseudo-differ-
±4.096V Fully Differential
ential unipolar (0V to 4.096V), and pseudo-differential
0V to 4.096V Pseudo-Differential Unipolar
bipolar (±2.048V) analog input ranges, allowing it to
±2.048V Pseudo-Differential Bipolar
interface with multiple signal chain formats without re- n
96.0dB (Fully Differential)/ 93.5dB (Pseudo
quiring additional level translation or signal conditioning.
Differential) SNR (Typ) at fIN = 2kHz
The LTC2389-16 achieves ±1LSB INL (maximum), no n –116dB (Fully Differential)/–112dB (Pseudo missing codes at 16-bits, and 96.0dB (fully differential)/ Differential) THD (Typ) at fIN = 2kHz 93.5dB (pseudo differential) SNR (typical). n Guaranteed Operation to 125°C The LTC2389-16 includes a precision internal 4.096V n Single 5V Supply reference, with a guaranteed 0.5% initial accuracy and a n Internal 20ppm/°C (Max) Reference ±20ppm/°C (maximum) temperature coefficient, as well n Internal Reference Buffer as an internal reference buffer. Fast 2.5Msps throughput n 162.5mW Power Dissipation at 2.5Msps with no cycle latency in the parallel interface modes n No Pipeline Delay, No Cycle Latency makes the LTC2389-16 ideally suited for a wide variety n 1.8V to 5V I/O Voltages of high speed applications. An internal oscillator sets n Parallel and Serial I/O Interface the conversion time, easing external timing considera- n 48-pin 7mm × 7mm LQFP and QFN Packages tions. The LTC2389-16 dissipates only 162.5mW at
applications
2.5Msps, while both nap and sleep power-down modes are provided to further reduce power consumption during n Medical Imaging inactive periods. n High Speed, Wide Dynamic Range Data Acquisition L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks and n Industrial Process Control SoftSpan is a trademark of Linear Technology Corporation. All other trademarks are the property of their respective owners. Protected by U.S. Patents, including 7705765. n Instrumentation n ATE
typical application 32k Point FFT fSMPL = 2.5Msps, fIN = 2kHz
5V 1.8V TO 5V 0 4.096V 10µF 0.1µF 0.1µF 10µF SNR = 96.0dB –20 THD = –116dB 0V SINAD = 96.0dB VDD OVDD PARALLEL OR –40 SFDR = 117dB SERIAL INTERFACE 16 BIT 0V A0 10Ω 49.9Ω –60 A1 IN+ 4.096V MODE0 + 1nF –80 MODE1 0V LTC2389-16 RESET –100 4.096V PD – 1nF CS –120 10Ω AMPLITUDE (dBFS) 0V OB/2C IN– PD/FD –140 49.9Ω 4.096V BUSY CNVST SAMPLE –160 VCM REFOUT REFIN REFSENSE GND 0V CLOCK –180 10µF 238916 TA01a 0 250 500 750 1000 1250 2.048V 1µF FREQUENCY (kHz) 238916 TA01b 238916f 1 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Analog Input Converter Characteristics Dynamic Accuracy Reference Characteristics Digital Inputs And Digital Outputs Power Requirements Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagrams Applications Information Package Description Related Parts Typical Application
