Datasheet LTC2389-18 (Analog Devices) - 6
Description18-Bit, 2.5Msps SAR ADC with Pin-Configurable Analog Input Range and 99.8dB SNR
Pages / Page40 / 6 — Timing. characTerisTics The. denotes the specifications which apply over …
File Format / SizePDF / 930 Kb
Timing. characTerisTics The. denotes the specifications which apply over the full operating temperature
Timing characTerisTics The denotes the specifications which apply over the full operating temperature
LTC2389-18
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4)
tHSDI SDI Hold Time From SCK↓ l 1 ns tDSDO SDO Data Valid Delay From SCK↑ CL = 15pF l 9 ns tHSDO SDO Data Remains Valid Delay From SCK↑ CL = 15pF l 1 ns tDDBUSYL Data Valid to BUSY↓ CL = 15pF l 1 ns tEN Bus Enable Time After CS↓ l 11 ns tDDA1A0 Data Valid Delay From A1 or A0 Transition CL = 15pF l 8 ns tDIS Bus Relinquish Time After CS↑ l 11 ns
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings zero-scale error is the offset voltage measured from 0.5LSB when the may cause permanent damage to the device. Exposure to any Absolute output code flickers between 00 0000 0000 0000 0000 and 00 0000 0000 Maximum Rating condition for extended periods may affect device 0000 0001. Bipolar zero-scale error is the offset voltage measured from reliability and lifetime. –0.5LSB when the output code flickers between 00 0000 0000 0000 0000
Note 2:
All voltage values are with respect to ground. and 11 1111 1111 1111 1111. Fully differential full-scale error is the
Note 3:
When these pin voltages are taken below ground or above worst-case deviation of the first and last code transitions from ideal and V includes the effect of offset error. Unipolar full-scale error is the deviation DD or OVDD, they will be clamped by internal diodes. This product can handle input currents up to 100mA below ground, or above V of the last code transition from ideal and includes the effect of offset error. DD or OVDD, without latchup. Bipolar full-scale error is the worst-case deviation of the first and last code transitions from ideal and includes the effect of offset error.
Note 4:
VDD = 5V, OVDD = 5V, VREF = 4.096V external reference, f
Note 8:
All specifications in dB are referred to a full-scale ±4.096V (fully SMPL = 2.5MHz, unless otherwise noted. differential), 0V to 4.096V (pseudo-differential unipolar), or ±2.048V
Note 5:
Recommended operating conditions. (pseudo-differential bipolar) input with a 4.096V reference voltage.
Note 6:
Integral nonlinearity is defined as the deviation of a code from a
Note 9:
Temperature coefficient is calculated by dividing the maximum straight line passing through the actual endpoints of the transfer curve. change in output voltage by the specified temperature range. The deviation is measured from the center of the quantization band.
Note 10:
Guaranteed by design, not subject to test.
Note 7:
Fully differential zero-scale error is the offset voltage measured from –0.5LSB when the output code flickers between 00 0000 0000 0000
Note 11:
A tSCK period of 10ns minimum allows a shift clock frequency of 0000 and 11 1111 1111 1111 1111 in two’s complement format. Unipolar up to 100MHz for rising capture. 0.8 • OVDD tWIDTH 0.2 • OVDD t tDELAY 50% 50% DELAY 238918 F01 0.8 • OVDD 0.8 • OVDD 0.2 • OVDD 0.2 • OVDD
Figure 1. Voltage Levels for Timing Specifications
238918f 6 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Analog Input Converter Characteristics Dynamic Accuracy Reference Characteristics Digital Inputs And Digital Outputs Power Requirements Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagrams Applications Information Package Description Typical Application Related Parts
