Datasheet LTC2410 (Analog Devices) - 3
Description24-Bit No Latency ∆Σ™ ADC with Differential Input and Differential Reference
Pages / Page50 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 804 Kb
LTC2410
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Notes 3, 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Total Unadjusted Error 5V ≤ VCC ≤ 5.5V, REF+ = 2.5V, REF– = GND, VINCM = 1.25V 3 ppm of VREF 5V ≤ VCC ≤ 5.5V, REF+ = 5V, REF– = GND, VINCM = 2.5V 3 ppm of VREF REF+ = 2.5V, REF– = GND, VINCM = 1.25V, (Note 6) 4 ppm of VREF Output Noise 5V ≤ VCC ≤ 5.5V, REF+ = 5V, REF– = GND, 0.8 µVRMS GND ≤ IN– = IN+ ≤ VCC, (Note 13)
CONVERTER CHARACTERISTICS The
Input Common Mode Rejection DC 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 130 140 dB GND ≤ IN– = IN+ ≤ VCC Input Common Mode Rejection 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 140 dB 60Hz ±2% GND ≤ IN– = IN+ ≤ VCC, (Note 7) Input Common Mode Rejection 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 140 dB 50Hz ±2% GND ≤ IN– = IN+ ≤ VCC, (Note 8) Input Normal Mode Rejection (Note 7) l 110 140 dB 60Hz ±2% Input Normal Mode Rejection (Note 8) l 110 140 dB 50Hz ±2% Reference Common Mode 2.5V ≤ REF+ ≤ VCC, GND ≤ REF– ≤ 2.5V, l 130 140 dB Rejection DC VREF = 2.5V, IN– = IN+ = GND Power Supply Rejection, DC REF+ = 2.5V, REF– = GND, IN– = IN+ = GND 120 dB Power Supply Rejection, 60Hz ±2% REF+ = 2.5V, REF– = GND, IN– = IN+ = GND, (Note 7) 120 dB Power Supply Rejection, 50Hz ±2% REF+ = 2.5V, REF– = GND, IN– = IN+ = GND, (Note 8) 120 dB
ANALOG INPUT AND REFERENCE The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IN+ Absolute/Common Mode IN+ Voltage l GND – 0.3V VCC + 0.3V V IN– Absolute/Common Mode IN– Voltage l GND – 0.3V VCC + 0.3V V VIN Input Differential Voltage Range l –VREF/2 VREF/2 V (IN+ – IN–) REF+ Absolute/Common Mode REF+ Voltage l 0.1 VCC V REF– Absolute/Common Mode REF– Voltage l GND VCC – 0.1V V VREF Reference Differential Voltage Range l 0.1 VCC V (REF+ – REF–) CS (IN+) IN+ Sampling Capacitance 18 pF CS (IN–) IN– Sampling Capacitance 18 pF CS (REF+) REF+ Sampling Capacitance 18 pF CS (REF–) REF– Sampling Capacitance 18 pF IDC_LEAK (IN+) IN+ DC Leakage Current CS = VCC, IN+ = GND l –10 1 10 nA IDC_LEAK (IN–) IN– DC Leakage Current CS = VCC, IN– = GND l –10 1 10 nA IDC_LEAK (REF+) REF+ DC Leakage Current CS = VCC, REF+ = 5V l –10 1 10 nA IDC_LEAK (REF–) REF– DC Leakage Current CS = VCC, REF– = GND l –10 1 10 nA 2410fa For more information www.linear.com/LTC2410 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Electrical Characteristics Converter Characteristics Analog Input and Reference Digital Inputs and Digital Outputs Power Requirements Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Test Circuit Applications Information Typical Applications Package Description PCB Layout and Film Revision History PCB Layout and Film Related Parts
