Datasheet LTC2411, LTC2411-1 (Analog Devices) - 4
Description24-Bit No Latency ∆Σ™ ADC with Differential Input and Reference in MSOP
Pages / Page42 / 4 — ANALOG INPUT AND REFERENCE. The. denotes the specifications which apply …
File Format / SizePDF / 598 Kb
ANALOG INPUT AND REFERENCE. The. denotes the specifications which apply over the full operating
ANALOG INPUT AND REFERENCE The denotes the specifications which apply over the full operating
LTC2411/LTC2411-1
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
CS (IN+) IN+ Sampling Capacitance 6 pF CS (IN–) IN– Sampling Capacitance 6 pF CS (REF+) REF+ Sampling Capacitance 6 pF CS (REF–) REF– Sampling Capacitance 6 pF IDC_LEAK (IN+) IN+ DC Leakage Current CS = VCC = 5.5V, IN+ = GND l –10 1 10 nA IDC_LEAK (IN–) IN– DC Leakage Current CS = VCC = 5.5V, IN– = GND l –10 1 10 nA IDC_LEAK (REF+) REF+ DC Leakage Current CS = VCC = 5.5V, REF+ = 5V l –10 1 10 nA IDC_LEAK (REF–) REF– DC Leakage Current CS = VCC = 5.5V, REF– = GND l –10 1 10 nA
DIGITAL INPUTS AND DIGITAL OUTPUTS The
l
VIH High Level Input Voltage 2.7V ≤ VCC ≤ 5.5V l 2.5 V CS, FO 2.7V ≤ VCC ≤ 3.3V 2.0 V VIL Low Level Input Voltage 4.5V ≤ VCC ≤ 5.5V l 0.8 V CS, FO 2.7V ≤ VCC ≤ 5.5V 0.6 V VIH High Level Input Voltage 2.7V ≤ VCC ≤ 5.5V (Note 9) l 2.5 V SCK 2.7V ≤ VCC ≤ 3.3V (Note 9) 2.0 V VIL Low Level Input Voltage 4.5V ≤ VCC ≤ 5.5V (Note 9) l 0.8 V SCK 2.7V ≤ VCC ≤ 5.5V (Note 9) 0.6 V IIN Digital Input Current 0V ≤ VIN ≤ VCC l –10 10 µA CS, FO IIN Digital Input Current 0V ≤ VIN ≤ VCC (Note 9) l –10 10 µA SCK CIN Digital Input Capacitance 10 pF CS, FO CIN Digital Input Capacitance (Note 9) 10 pF SCK VOH High Level Output Voltage IO = –800µA l VCC – 0.5V V SDO V VOL Low Level Output Voltage IO = 1.6mA l 0.4 V SDO V VOH High Level Output Voltage IO = –800µA (Note 10) l VCC – 0.5V V SCK V VOL Low Level Output Voltage IO = 1.6mA (Note 10) l 0.4 V SCK V IOZ Hi-Z Output Leakage l –10 10 µA SDO
POWER REQUIREMENTS The
l
VCC Supply Voltage l 2.7 5.5 V ICC Supply Current Conversion Mode CS = 0V (Note 12) l 200 300 µA Sleep Mode CS = VCC (Note 12) l 4 10 µA Sleep Mode CS = VCC, 2.7V ≤ VCC ≤ 3.3V (Note 12) 2 µA 2411fa 4 For more information www.linear.com/LTC2411
