Datasheet LTC2483 (Analog Devices) - 7
Description | 16-Bit ΔΣ ADC with Easy Drive Input Current Cancellation and I2C Interface |
Pages / Page | 34 / 7 — RMS Noise. vs Input Differential Voltage. RMS Noise vs VIN(CM). RMS Noise … |
File Format / Size | PDF / 2.9 Mb |
RMS Noise. vs Input Differential Voltage. RMS Noise vs VIN(CM). RMS Noise vs Temperature (TA). RMS Noise vs VCC
LTC2483 Typical perFormance characTerisTics
RMS Noise vs Input Differential Voltage RMS Noise vs VIN(CM) RMS Noise vs Temperature (TA)
1.0 1.0 1.0 VCC = 5V VCC = 5V VCC = 5V VREF = 5V VREF = 5V VREF = 5V 0.9 V 0.9 V 0.9 V ) IN(CM) = 2.5V IN = 0V IN = 0V TA = 25°C VIN(CM) = GND VIN(CM) = GND REF TA = 25°C 0.8 0.8 0.8 0.7 0.7 0.7 0.6 RMS NOISE (µV) 0.6 RMS NOISE (µV) 0.6 RMS NOISE (ppm OF V 0.5 0.5 0.5 0.4 0.4 0.4 –2.5 –2 –1.5 –1 –0.5 0 0.5 1 1.5 2 2.5 –1 0 1 2 3 4 5 6 –45 –30 –15 0 15 30 45 60 75 90 INPUT DIFFERENTIAL VOLTAGE (V) VIN(CM) (V) TEMPERATURE (°C) 2483 G10 2483 G11 2483 G12
RMS Noise vs VCC RMS Noise vs VREF Offset Error vs VIN(CM)
1.0 1.0 0.3 VREF = 2.5V VCC = 5V VCC = 5V VIN = 0V VIN = 0V VREF = 5V 0.9 VIN(CM) = GND 0.9 VIN(CM) = GND ) 0.2 VIN = 0V TA = 25°C TA = 25°C REF TA = 25°C 0.8 0.8 0.1 0.7 0.7 0 RMS NOISE (µV) 0.6 RMS NOISE (µV) 0.6 –0.1 0.5 0.5 OFFSET ERROR (ppm OF V –0.2 0.4 0.4 –0.3 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 0 1 2 3 4 5 –1 0 1 2 3 4 5 6 VCC (V) VREF (V) VIN(CM) (V) 2483 G13 2483 G14 2483 G15
Offset Error vs Temperature Offset Error vs VCC Offset Error vs VREF
0.3 0.3 0.3 VCC = 5V REF+ = 2.5V VCC = 5V VREF = 5V REF – = GND REF– = GND ) 0.2 VIN = 0V ) 0.2 VIN = 0V ) 0.2 VIN = 0V REF VIN(CM) = GND REF VIN(CM) = GND REF VIN(CM) = GND T T 0.1 0.1 A = 25°C A = 25°C 0.1 0 0 0 –0.1 –0.1 –0.1 OFFSET ERROR (ppm OF V –0.2 OFFSET ERROR (ppm OF V –0.2 OFFSET ERROR (ppm OF V –0.2 –0.3 –0.3 –0.3 –45 –30 –15 0 15 30 45 60 75 90 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 0 1 2 3 4 5 TEMPERATURE (°C) VCC (V) VREF (V) 2483 G16 2483 G17 2483.G18 2483fc Document Outline Features Applications Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Analog Input and Reference I2C Digital Inputs and Digital Outputs Power Requirements Timing Characteristics I2C Timing Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Package Description Revision History Typical Application Related Parts
