Datasheet LTC2485 (Analog Devices) - 7
Description | 24-Bit ΔΣ ADC with Easy Drive Input Current Cancellation and I2C Interface |
Pages / Page | 40 / 7 — Typical perForMance characTerisTics. RMS Noise. vs Input Differential … |
File Format / Size | PDF / 646 Kb |
Typical perForMance characTerisTics. RMS Noise. vs Input Differential Voltage. RMS Noise vs VIN(CM)
LTC2485
Typical perForMance characTerisTics RMS Noise vs Input Differential Voltage RMS Noise vs VIN(CM) RMS Noise vs Temperature (TA)
1.0 1.0 1.0 VCC = 5V VCC = 5V VCC = 5V VREF = 5V VREF = 5V VREF = 5V 0.9 V 0.9 V 0.9 V ) IN(CM) = 2.5V IN = 0V IN = 0V TA = 25°C VIN(CM) = GND VIN(CM) = GND REF TA = 25°C 0.8 0.8 0.8 0.7 0.7 0.7 0.6 RMS NOISE (µV) 0.6 RMS NOISE (µV) 0.6 RMS NOISE (ppm OF V 0.5 0.5 0.5 0.4 0.4 0.4 –2.5 –2 –1.5 –1 –0.5 0 0.5 1 1.5 2 2.5 –1 0 1 2 3 4 5 6 –45 –30 –15 0 15 30 45 60 75 90 INPUT DIFFERENTIAL VOLTAGE (V) VIN(CM) (V) TEMPERATURE (°C) 2485 G10 2485 G11 2485 G12
RMS Noise vs VCC RMS Noise vs VREF Offset Error vs VIN(CM)
1.0 1.0 0.3 VREF = 2.5V VCC = 5V VCC = 5V VIN = 0V VIN = 0V VREF = 5V 0.9 VIN(CM) = GND 0.9 VIN(CM) = GND ) 0.2 VIN = 0V TA = 25°C TA = 25°C REF TA = 25°C 0.8 0.8 0.1 0.7 0.7 0 RMS NOISE (µV) 0.6 RMS NOISE (µV) 0.6 –0.1 0.5 0.5 OFFSET ERROR (ppm OF V –0.2 0.4 0.4 –0.3 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 0 1 2 3 4 5 –1 0 1 2 3 4 5 6 VCC (V) VREF (V) VIN(CM) (V) 2485 G13 2485 G14 2485 G15
Offset Error vs Temperature Offset Error vs VCC Offset Error vs VREF
0.3 0.3 0.3 VCC = 5V REF+ = 2.5V VCC = 5V VREF = 5V REF– = GND REF– = GND ) 0.2 V 0.2 IN = 0V ) 0.2 VIN = 0V ) VIN = 0V REF VIN(CM) = GND REF VIN(CM) = GND REF VIN(CM) = GND T TA = 25°C 0.1 0.1 A = 25°C 0.1 0 0 0 –0.1 –0.1 –0.1 OFFSET ERROR (ppm OF V OFFSET ERROR (ppm OF V –0.2 –0.2 OFFSET ERROR (ppm OF V –0.2 –0.3 –0.3 –0.3 –45 –30 –15 0 15 30 45 60 75 90 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 0 1 2 3 4 5 TEMPERATURE (°C) VCC (V) VREF (V) 2485 G16 2485 G17 2485.G18 2485fd For more information www.linear.com/LTC2485 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (Normal Speed) Electrical Characteristics (2x Speed) Converter Characteristics Analog Input and Reference I2C Digital Inputs and Digital Outputs Power Requirements Timing Characteristics I2C Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Applications Information Package Description Revision History Typical Application Related Parts
