Datasheet LTC2492 (Analog Devices) - 7
Description | 24-Bit 2-/4-Channel ΔΣ ADC with Easy Drive Input Current Cancellation |
Pages / Page | 38 / 7 — Typical perFormance characTerisTics. RMS Noise. vs Input Differential … |
File Format / Size | PDF / 619 Kb |
Typical perFormance characTerisTics. RMS Noise. vs Input Differential Voltage. RMS Noise vs VIN(CM)
LTC2492
Typical perFormance characTerisTics RMS Noise vs Input Differential Voltage RMS Noise vs VIN(CM) RMS Noise vs Temperature (TA)
1.0 1.0 1.0 VCC = 5V VCC = 5V VCC = 5V VREF = 5V VREF = 5V VREF = 5V 0.9 VIN(CM) = 2.5V 0.9 VIN = 0V 0.9 VIN = 0V TA = 25°C TA = 25°C VIN(CM) = GND 0.8 0.8 0.8 0.7 0.7 0.7 RMS NOISE (µV) 0.6 RMS NOISE (µV) 0.6 RMS NOISE (µV) 0.6 0.5 0.5 0.5 0.4 0.4 0.4 –2.5 –2 –1.5 –1 –0.5 0 0.5 1 1.5 2 2.5 –1 0 1 2 3 4 5 6 –45 –30 –15 0 15 30 45 60 75 90 INPUT DIFFERENTIAL VOLTAGE (V) VIN(CM) (V) TEMPERATURE (°C) 2492 G10 2492 G11 2492 G12
RMS Noise vs VCC RMS Noise vs VREF Offset Error vs VIN(CM)
1.0 1.0 0.3 V V REF = 2.5V CC = 5V VCC = 5V V V IN = 0V IN = 0V VREF = 5V 0.9 V 0.9 V IN(CM) = GND IN(CM) = GND ) 0.2 VIN = 0V T T A = 25°C A = 25°C REF TA = 25°C 0.8 0.8 0.1 0.7 0.7 0 RMS NOISE (µV) RMS NOISE (µV) 0.6 0.6 –0.1 0.5 0.5 OFFSET ERROR (ppm OF V –0.2 0.4 0.4 –0.3 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 0 1 2 3 4 5 –1 0 1 2 3 4 5 6 V V CC (V) REF (V) VIN(CM) (V) 2492 G13 2492 G14 2492 G15
Offset Error vs Temperature Offset Error vs VCC Offset Error vs VREF
0.3 0.3 0.3 VCC = 5V REF+ = 2.5V VCC = 5V VREF = 5V REF– = GND REF– = GND ) 0.2 VIN = 0V ) 0.2 VIN = 0V ) 0.2 VIN = 0V REF VIN(CM) = GND REF VIN(CM) = GND REF VIN(CM) = GND F T T 0.1 O = GND 0.1 A = 25°C A = 25°C 0.1 0 0 0 –0.1 –0.1 –0.1 OFFSET ERROR (ppm OF V –0.2 OFFSET ERROR (ppm OF V –0.2 OFFSET ERROR (ppm OF V –0.2 –0.3 –0.3 –0.3 –45 –30 –15 0 15 30 45 60 75 90 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 0 1 2 3 4 5 TEMPERATURE (°C) VCC (V) VREF (V) 2492 G16 2492 G17 2492 G18 2492fe For more information www.linear.com/LTC2492 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics (Normal Speed) Pin Configuration Electrical Characteristics (2x Speed) Converter Characteristics Analog Input and Reference Digital Inputs and Digital Outputs Power Requirements Digital Inputs and Digital Outputs Typical Performance Characteristics Pin Functions Functional Block Diagram Test Circuits Timing Diagrams Applications Information Package Description Revision History Typical Application Related Parts
