Datasheet LTC1380, LTC1393 (Analog Devices)
DescriptionSingle-Ended 8-Channel/ Differential 4-Channel Analog Multiplexer with SMBus Interface
Pages / Page12 / 1 — FEATURES. DESCRIPTION. APPLICATIONS. TYPICAL APPLICATION. LTC1380 …
RevisionLTC1380/LTC1393: Single-Ended 8-Channel/ Differential 4-Channel Analog Multiplexer with SMBus Interface Data Sheet
File Format / SizePDF / 246 Kb
FEATURES. DESCRIPTION. APPLICATIONS. TYPICAL APPLICATION. LTC1380 Single-Ended 8-Channel Multiplexer. On Resistance vs VS
Datasheet LTC1380, LTC1393 Analog Devices, Revision: LTC1380/LTC1393: Single-Ended 8-Channel/ Differential 4-Channel Analog Multiplexer with SMBus Interface Data Sheet
LTC1380/LTC1393 Single-Ended 8-Channel/ Differential 4-Channel Analog Multiplexer with SMBus Interface
U FEATURES DESCRIPTION
■ Micropower Operation: Supply Current = 20µA Max The LTC®1380/LTC1393 are CMOS analog multiplexers with ■ 2-Wire SMBus Interface SMBus® compatible digital interfaces. The LTC1380 is a ■ Single 2.7V to ±5V Supply Operation single-ended 8-channel multiplexer, while the LTC1393 is a ■ Expandable to 32 Single or 16 Differential Channels differential 4-channel multiplexer. The SMBus digital inter- ■ Guaranteed Break-Before-Make face requires only two wires (SCL and SDA). Both the ■ Low RON: 35Ω Single Ended/70Ω Differential LTC1380 and the LTC1393 have four hard-wired SMBus ■ Low Charge Injection: 20pC Max addresses, selectable with two external address pins. This ■ Low Leakage: ±5nA Max allows four devices, each with a unique SMBus address, to ■ Available in 16-Lead SO and GN Packages coexist on one system and for four devices to be synchro- nized with one stop bit.
U
The supply current is typically 10µA. Both digital interface
pins are SMBus compatible over the full operating supply ■ Data Acquisition Systems voltage range. The LTC1380 analog switches feature a ■ Process Control typical RON of 35Ω (±5V supplies), typical switch leakage of ■ Laptop Computers 20pA and guaranteed break-before-make operation. Charge ■ Signal Multiplexing/Demultiplexing injection is ±1pC typical. ■ Analog-to-Digital Conversion Systems The LTC1380/LTC1393 are available in 16-lead SO and GN packages. Operation is fully specified over the commercial and industrial temperature ranges. , LTC and LT are registered trademarks of Linear Technology Corporation. SMBus is a registered trademark of Intel Corporation.
U TYPICAL APPLICATION LTC1380 Single-Ended 8-Channel Multiplexer On Resistance vs VS
5V 250 TA = 25°C 225 ID = 1mA 1 16 SMBus 200 0.1µF 15k 15k S0 VCC HOST ) VCC = 2.7V 2 15 Ω 175 V S1 SCL SCL EE = 0V 3 14 150 S2 SDA SDA 4 13 125 8 ANALOG S3 A0 5 LTC1380 12 INPUTS 100 VCC = 5V S4 A1 VEE = 0V 6 11 ON RESISTANCE ( 75 V S5 GND 0.1µF CC = 5V V 7 10 50 EE = – 5V S6 V – 5V EE 8 9 25 S7 D ANALOG OUTPUT 1380/93 TA01 O 0–5 –4 –3 –2 –1 0 1 2 3 4 5 VS (V) 1167 G15 1
