Datasheet LTC201A, LTC202, LTC203 (Analog Devices) - 3
DescriptionMicropower, Low Charge Injection, Quad CMOS Analog Switches
Pages / Page16 / 3 — DIGITAL A D DC ELECTRICAL CHARACTERISTICS The. denotes the specifications …
RevisionLTC201A/LTC202/LTC203: Micropower, Low Charge Injection, Quad CMOS Analog Switches Data Sheet
File Format / SizePDF / 208 Kb
DIGITAL A D DC ELECTRICAL CHARACTERISTICS The. denotes the specifications which
DIGITAL A D DC ELECTRICAL CHARACTERISTICS The denotes the specifications which
U DIGITAL A D DC ELECTRICAL CHARACTERISTICS The
denotes the specifications which apply over full operating temperature range, otherwise specifications are at TA = 25
C. V+ = 15V, V– = –15V, GND = 0V. LTC201AM/LTC202M/ LTC201AC/LTC202C/ LTC203M LTC203C PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Off Output Leakage ID (0FF) VD = ±14V, VS = ±14V ● 0.01 ±1 0.01 ±5 nA Switch Off ±100 ±100 nA On Channel Leakage lD (ON) VD = VS = ±14V 0.02 ±1 0.02 ±5 nA Switch On ● ±200 ±200 nA Input High Voltage VINH ● 2.4 2.4 V Input Low Voltage VINL ● 0.8 0.8 V Input High or Low Current VIN = 15V, 0V ● ±1 ±1 µA IINH and IINL CS (OFF) 5 5 pF CD (OFF) 12 12 pF CD, CS (ON) 30 30 pF I+ All Logic Inputs Tied Together 16 40 16 40 µA VIN = 0V or 4.0V ● 60 60 µA I – 0.1 5 0.1 5 µA ● 10 10 µA
AC ELECTRICAL CHARACTERISTICS V+ = 15V, V– = –15V, GND = 0V unless otherwise noted. LTC201AM/LTC202M/ LTC201AC/LTC202C/ LTC203M LTC203C PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
tON VS = 2V, RL = 1kΩ, CL = 35pF 290 400 290 400 ns tOFF 210 300 210 300 ns tOPEN 20 85 20 85 ns Off Isolation VS = 2VP-P, RL = 1kΩ, f 100kHz 75 75 dB Crosstalk 90 90 dB Charge Injection OINJ RS = 0Ω, CL = 1000pF, VS = 0V 5 ±25 8 ±25 pC Total Harmonic Distortion THD VS = 2VP-P, RL = 10kΩ 0.01 0.01 % 201a23fb 3
