Datasheet LT1083, LT1084, LT1085 (Analog Devices) - 14
Description | 7.5A, 5A, 3A Low Dropout Positive Adjustable Regulators |
Pages / Page | 22 / 14 — Typical applicaTion. 7.5A Variable Regulator |
File Format / Size | PDF / 293 Kb |
LT1083/LT1084/LT1085
Typical applicaTion 7.5A Variable Regulator
T1 TRIAD L C30B F-269U 1mH IN LT1083 OUT 0V TO 35V + OA TO 7.5A ADJ 20Ω T2 3 + 750Ω* 1.5k 100µF 110VAC 1N4003 C1 LT1004-1.2 50,000µF 20Ω 1 2 C30B 1N914 2k 1N4003 1N4003 OUTPUT ADJUST 16k* 1µF 560Ω 15V LT1004-1.2 82k 15k 8 –15V 16k* 2.7k 200k 11k* 2 + 4 7 –15V LT1011 3 10k – 0.1µF 1 1N4148 NC 15V 100pF –15V 8 2N3904 4 – 3 1 7 LT1011 8 + 3 10k + 2 6 LM301A * 1% FILM RESISTOR 1 L: DALE TO-5 TYPE 7 – 2 15K T2: STANCOR 11Z-2003 15V 4 11k* GENERAL PURPOSE REGULATOR WITH SCR PREREGULATOR –15V 15V TO LOWER POWER DISSIPATION. ABOUT 1.7V DIFFERENTIAL IS MAINTAINED ACROSS THE LT1083 INDEPENDENT OF OUTPUT VOLTAGE AND LOAD CURRENT 1µF LT1083/4/5 ADJ TA05 108345fh 14 For more information www.linear.com/LT1083 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Block Diagram Applications Information Typical Application Package Description Revision History Typical Applications Related Parts
