Datasheet LT1086 (Analog Devices)
Description1.5A Low Dropout Positive Regulators Adjustable and Fixed 2.85V, 3.3V, 3.6V, 5V, 12V
Pages / Page16 / 1 — FEATURES. DESCRIPTIO. APPLICATIO S. TYPICAL APPLICATIO. LT1086 Dropout …
File Format / SizePDF / 227 Kb
FEATURES. DESCRIPTIO. APPLICATIO S. TYPICAL APPLICATIO. LT1086 Dropout Voltage. 5V to 3.3V Regulator
Datasheet LT1086 Analog Devices
LT1086 Series 1.5A Low Dropout Positive Regulators Adjustable and Fixed 2.85V, 3.3V, 3.6V, 5V, 12V
U FEATURES DESCRIPTIO
■ 3-Terminal Adjustable or Fixed The LT ®1086 is designed to provide up to 1.5A output 2.85V, 3.3V, 3.6V, 5V, 12V current. All internal circuitry is designed to operate down ■ Output Current of 1.5A (0.5A for LT1086H) to 1V input-to-output differential and the dropout voltage ■ Operates Down to 1V Dropout is fully specified as a function of load current. Dropout is ■ Guaranteed Dropout Voltage at Multiple Current Levels guaranteed at several operating points up to a maximum ■ Line Regulation: 0.015% of 1.5V at maximum output current. Dropout decreases at ■ Load Regulation: 0.1% lower load currents. On-chip trimming adjusts the refer- ■ 100% Thermal Limit Functional Test ence/ouput voltage to 1%. Current limit is also trimmed, ■ Ripple Rejection >75dB minimizing the stress on both the regulator and power ■ Available in 3-Pin TO-220 and 3-Pin DD Packages source circuitry under overload conditions.
U
The LT1086 is pin compatible with older 3-terminal adjust-
APPLICATIO S
able regulators. A minimum 10µF output capacitor is required on these devices. ■ SCSI-2 Active Terminator The LT1086 offers excellent line and load regulation speci- ■ High Efficiency Linear Regulators fications and ripple rejection exceeds 75dB even at the ■ Post Regulators for Switching Supplies maximum load current of 1.5A. The LT1086 is floating ■ Constant Current Regulators architecture with a composite NPN output stage. All of the ■ Battery Chargers quiescent current and the drive current for the output ■ Microprocessor Supply stage flows to the load increasing efficiency. The LT1086 is available in a 3-pin TO-220 package and a space-saving surface mountable 3-pin DD package. , LTC and LT are registered trademarks of Linear Technology Corporation.
U TYPICAL APPLICATIO LT1086 Dropout Voltage
2 INDICATES GUARANTEED TEST POINT
–55°C ≤ TJ ≤ 150°C 0°C ≤ TJ ≤ 125°C VIN ≥ 4.75V IN LT1086-3.3 OUT 3.3V AT 1.5A GND 1 10µF* 10µF T TANTALUM TANTALUM J = – 55°C TJ = 25°C TJ = 150°C LT1086 • TA01 *MAY BE OMITTED IF INPUT SUPPLY IS WELL MINIMUM INPUT/OUTPUT DIFFERENTIAL (V) 0 BYPASSED WITHIN 2" OF THE LT1086 0 0.5 1 1.5 OUTPUT CURRENT (A) LT1086 • TA02 sn1086 1086ffs 1
