Datasheet LT1965 (Analog Devices) - 2
Description1.1A, Low Noise, Low Dropout Linear Regulator
Pages / Page22 / 2 — absolute MaxiMuM ratings (Note 1). pin conFiguration. orDer inForMation …
File Format / SizePDF / 998 Kb
absolute MaxiMuM ratings (Note 1). pin conFiguration. orDer inForMation LEAD FREE FINISH. TAPE AND REEL. PART MARKING
absolute MaxiMuM ratings (Note 1) pin conFiguration orDer inForMation LEAD FREE FINISH TAPE AND REEL PART MARKING
LT1965
LT1965 Series
IN Pin Voltage ...±22V Output Short-Circuit Duration .. Indefinite OUT Pin Voltage ..±22V Operating Junction Temperature Range (Notes 3, 5, 13) Input to Output Differential Voltage (Note 2) ... ±22V E-, I-Grades ... –40°C to 125°C SENSE Pin Voltage ..±22V H-Grade ... –40°C to 150°C ADJ Pin Voltage ..±9V Storage Temperature Range ..–65°C to 150°C SHDN Pin Voltage ...±22V Lead Temperature (Soldering, 10 sec) (Only for MSOP, TO-220, DD-Pak Packages) ..300°C
pin conFiguration
TOP VIEW TOP VIEW OUT 1 8 IN OUT 1 8 IN OUT 2 7 IN 9 OUT 2 7 9 IN SENSE/ADJ* 3 6 SHDN SENSE/ADJ* 3 6 SHDN GND 4 5 GND GND 4 5 GND MS8E PACKAGE 8-LEAD PLASTIC MSOP DD PACKAGE T 8-LEAD (3mm × 3mm) PLASTIC DFN JMAX = 125°C, θJA = 60°C/W, θJC = 10°C/W EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB TJMAX = 150°C, θJA = 65°C/W, θJC = 3°C/W *PIN 3 = SENSE FOR LT1965-1.5/LT1965-1.8/LT1965-2.5/LT1965-3.3 EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB *PIN 3 = ADJ FOR LT1965 *PIN 3 = SENSE FOR LT1965-1.5/LT1965-1.8/LT1965-2.5/LT1965-3.3 *PIN 3 = ADJ FOR LT1965 FRONT VIEW FRONT VIEW 5 SENSE/ADJ* 5 SENSE/ADJ* 4 OUT 4 OUT TAB IS TAB IS 3 GND GND 3 GND GND 2 IN 2 IN 1 SHDN 1 SHDN Q PACKAGE T PACKAGE 5-LEAD PLASTIC DD-PAK 5-LEAD PLASTIC TO-220 TJMAX = 150°C, θJA = 30°C/W, θJC = 3°C/W TJMAX = 150°C, θJA = 50°C/W, θJC = 3°C/W *PIN 5 = SENSE FOR LT1965-1.5/LT1965-1.8/LT1965-2.5/LT1965-3.3 *PIN 5 = SENSE FOR LT1965-1.5/LT1965-1.8/LT1965-2.5/LT1965-3.3 *PIN 5 = ADJ FOR LT1965 *PIN 5 = ADJ FOR LT1965
PACKAGE DESCRIPTION TEMPERATURE RANGE
LT1965EDD#PBF LT1965EDD#TRPBF LCXW 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1965IDD#PBF LT1965IDD#TRPBF LCXW 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1965EDD-1.5#PBF LT1965EDD-1.5#TRPBF LDKW 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1965IDD-1.5#PBF LT1965IDD-1.5#TRPBF LDKW 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1965EDD-1.8#PBF LT1965EDD-1.8#TRPBF LDKY 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1965IDD-1.8#PBF LT1965IDD-1.8#TRPBF LDKY 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1965EDD-2.5#PBF LT1965EDD-2.5#TRPBF LDMB 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1965IDD-2.5#PBF LT1965IDD-2.5#TRPBF LDMB 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1965EDD-3.3#PBF LT1965EDD-3.3#TRPBF LDMD 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C 1965fb 2 For more information www.linear.com/LT1965 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Revision History Related Parts
