Datasheet LT3011 (Analog Devices) - 2
Description50mA, 3V to 80V Low Dropout Micropower Linear Regulator with PWRGD
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 236 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3011
IN Pin Voltage ...±80V Storage Temperature Range ... –65°C to 150°C OUT Pin Voltage ..±60V Operating Junction Temperature Input-to-Output Differential Voltage ..±80V (Notes 3, 10, 11) ADJ Pin Voltage ..±7V LT3011E, LT3011I .. –40°C to 125°C SHDN Pin Voltage ...±80V LT3011H .. –40°C to 150°C CT Pin Voltage .. 7V, –0.5V Lead Temperature (Soldering, 10 sec) PWRGD Pin Voltage ... 80V, –0.5V MSE Package Only .. 300°C Output Short-Circuit Duration .. Indefi nite
PIN CONFIGURATION
TOP VIEW TOP VIEW OUT 1 10 IN NC 1 12 NC ADJ 2 9 NC OUT 2 11 IN 11 ADJ 3 10 NC GND 3 8 SHDN 13 GND 4 9 SHDN NC 4 7 NC NC 5 8 NC PWRGD 5 6 CT PWRGD 6 7 CT MSE PACKAGE DD PACKAGE 12-LEAD PLASTIC MSOP 10-LEAD (3mm s 3mm) PLASTIC DFN T T JMAX = 150°C, θJA = 40°C/W, θJC = 16°C/W JMAX = 150°C, θJA = 43°C/W, θJC = 16°C/W EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB
LT3011EDD#PBF LT3011EDD#TRPBF LDKQ 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3011IDD#PBF LT3011IDD#TRPBF LDKQ 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3011EMSE#PBF LT3011EMSE#TRPBF 3011 12-Lead Plastic MSOP –40°C to 125°C LT3011HMSE#PBF LT3011HMSE#TRPBF 3011 12-Lead Plastic MSOP –40°C to 150°C LT3011IMSE#PBF LT3011IMSE#TRPBF 3011 12-Lead Plastic MSOP –40°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3011EDD LT3011EDD#TR LDKQ 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3011IDD LT3011IDD#TR LDKQ 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3011EMSE LT3011EMSE#TR 3011 12-Lead Plastic MSOP –40°C to 125°C LT3011HMSE LT3011HMSE#TR 3011 12-Lead Plastic MSOP –40°C to 150°C LT3011IMSE LT3011IMSE#TR 3011 12-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3011f 2
