Datasheet LT3013 (Analog Devices) - 3
Description | 250mA, 4V to 80V Low Dropout Micropower Linear Regulator with PWRGD |
Pages / Page | 20 / 3 — ELECTRICAL CHARACTERISTICS (LT3013E, LT3013MP). The |
File Format / Size | PDF / 233 Kb |
LT3013
ELECTRICAL CHARACTERISTICS (LT3013E, LT3013MP) The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TJ = 25°C. PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage ILOAD = 250mA l 4 4.75 V ADJ Pin Voltage (Notes 2,3) VIN = 4V, ILOAD = 1mA 1.225 1.24 1.255 V 4.75V < VIN < 80V, 1mA < ILOAD < 250mA l 1.2 1.24 1.28 V Line Regulation ΔVIN = 4V to 80V, ILOAD = 1mA (Note 2) l 0.1 5 mV Load Regulation (Note 2) VIN = 4.75V, ΔILOAD = 1mA to 250mA 7 12 mV VIN = 4.75V, ΔILOAD = 1mA to 250mA l 25 mV Dropout Voltage ILOAD = 10mA 160 230 mV VIN = VOUT(NOMINAL) (Notes 4, 5) ILOAD = 10mA l 300 mV ILOAD = 50mA 250 340 mV ILOAD = 50mA l 420 mV ILOAD = 250mA 400 490 mV ILOAD = 250mA l 620 mV GND Pin Current ILOAD = 0mA l 65 120 μA VIN = 4.75V ILOAD = 100mA 3 mA (Notes 4, 6) ILOAD = 250mA l 10 18 mA Output Voltage Noise COUT = 10μF, ILOAD = 250mA, BW = 10Hz to 100kHz 100 μVRMS ADJ Pin Bias Current (Note 7 ) 30 100 nA Shutdown Threshold VOUT = Off to On l 1.3 2 V VOUT = On to Off l 0.3 0.8 V SHDN Pin Current (Note 8) VSHDN = 0V 0.3 2 μA VSHDN = 6V 0.1 1 μA Quiescent Current in Shutdown VIN = 6V, VSHDN = 0V 1 5 μA PWRGD Trip Point % of Nominal Output Voltage, Output Rising l 85 90 94 % PWRGD Trip Point Hysteresis % of Nominal Output Voltage 1.1 % PWRGD Output Low Voltage IPWRGD = 50μA l 140 250 mV CT Pin Charging Current 3.0 6 μA CT Pin Voltage Differential VCT(PWRGD High) – VCT(PWRGD Low) 1.6 V Ripple Rejection VIN = 7V(Avg), VRIPPLE = 0.5VP-P, fRIPPLE = 120Hz, ILOAD = 250mA 65 75 dB Current Limit VIN = 7V, VOUT = 0V 400 mA VIN = 4.75V, ΔVOUT = –0.1V (Note 2) l 250 mA Reverse Output Current (Note 9) VOUT = 1.24V, VIN < 1.24V (Note 2) 12 25 μA
ELECTRICAL CHARACTERISTICS (LT3013H) The
l
denotes the specifi cations which apply over the –40°C to 140°C operating temperature range, otherwise specifi cations are at TJ = 25°C. PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage ILOAD = 200mA l 4 4.75 V ADJ Pin Voltage (Notes 2,3) VIN = 4V, ILOAD = 1mA 1.225 1.24 1.255 V 4.75V < VIN < 80V, 1mA < ILOAD < 200mA l 1.2 1.24 1.28 V Line Regulation ΔVIN = 4V to 80V, ILOAD = 1mA (Note 2) l 0.1 5 mV Load Regulation (Note 2) VIN = 4.75V, ΔILOAD = 1mA to 200mA 6 12 mV VIN = 4.75V, ΔILOAD = 1mA to 200mA l 30 mV 3013fe 3
