Datasheet LT3014 (Analog Devices) - 2
Description20mA, 3V to 80V Low Dropout Micropower Linear Regulator
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
File Format / SizePDF / 185 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3014
IN Pin Voltage, Operating ... ±80V Storage Temperature Range Transient (2ms Survival, LT3014HV) .. +100V ThinSOT Package .. –65°C to 150°C OUT Pin Voltage ... ±60V DFN Package ..–65°C to 125°C IN to OUT Differential Voltage .. ±80V Operating Junction Temperature Range ADJ Pin Voltage ... ±7V (Notes 3, 10, 11) ..–40°C to 125°C SHDN Pin Input Voltage ... ±80V Lead Temperature Output Short-Circuit Duration ..Indefi nite (Soldering, 10 sec, SOT-23 Package) ..300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW OUT 1 8 IN IN 1 5 OUT ADJ 2 7 NC GND 2 9 NC 3 6 NC SHDN 3 4 ADJ GND 4 5 SHDN S5 PACKAGE 5-LEAD PLASTIC SOT-23 DD PACKAGE TJMAX = 125°C, θJA = 150°C/ W 8-LEAD (3mm s 3mm) PLASTIC DFN θJC = 25°C/W MEASURED AT PIN 2 EXPOSED PAD IS GND (PIN 9) MUST BE SOLDERED TO PCB SEE APPLICATIONS INFORMATION SECTION TJMAX = 125°C, θJA = 40°C/ W θJC = 10°C/W MEASURED AT PIN 9
LT3014ES5#PBF LT3014ES5#TRPBF LTBMF 5-Lead Plastic SOT-23 –40°C to 125°C LT3014IS5#PBF LT3014IS5#TRPBF LTBMF 5-Lead Plastic SOT-23 –40°C to 125°C LT3014HVES5#PBF LT3014HVES5#TRPBF LTBRS 5-Lead Plastic SOT-23 –40°C to 125°C LT3014HVIS5#PBF LT3014HVIS5#TRPBF LTBRS 5-Lead Plastic SOT-23 –40°C to 125°C LT3014EDD#PBF LT3014EDD#TRPBF LBMG 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3014IDD#PBF LT3014IDD#TRPBF LBMG 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3014HVEDD#PBF LT3014HVEDD#TRPBF LBRT 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3014HVIDD#PBF LT3014HVIDD#TRPBF LBRT 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3014ES5 LT3014ES5#TR LTBMF 5-Lead Plastic SOT-23 –40°C to 125°C LT3014IS5 LT3014IS5#TR LTBMF 5-Lead Plastic SOT-23 –40°C to 125°C LT3014HVES5 LT3014HVES5#TR LTBRS 5-Lead Plastic SOT-23 –40°C to 125°C LT3014HVIS5 LT3014HVIS5#TR LTBRS 5-Lead Plastic SOT-23 –40°C to 125°C LT3014EDD LT3014EDD#TR LBMG 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3014IDD LT3014IDD#TR LBMG 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3014HVEDD LT3014HVEDD#TR LBRT 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3014HVIDD LT3014HVIDD#TR LBRT 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3014fd 2
