Datasheet LT3029 (Analog Devices) - 2
Description | Dual 500mA/500mA Low Dropout, Low Noise, Micropower Linear Regulator |
Pages / Page | 20 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion … |
File Format / Size | PDF / 1.7 Mb |
absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
LT3029
IN1, IN2 Pin Voltage ..±22V Operating Junction Temperature (Notes 2, 12) OUT1, OUT2 Pin Voltage ...±22V LT3029E ... –40°C to 125°C Input-to-Output Differential Voltage ..±22V LT3029I .. –40°C to 125°C ADJ1, ADJ2 Pin Voltage ..±9V LT3029H .. –40°C to 150°C BYP1, BYP2 Pin Voltage ..±0.6V LT3029MP.. –55°C to 125°C SHDN1 , SHDN2 Pin Voltage ..±22V Storage Temperature Range ... –65°C to 150°C Output Short-Circuit Duration .. Indefinite Lead Temperature (Soldering, 10 sec) (MSOP Only) ... 300°C
pin conFiguraTion
TOP VIEW BYP1 1 16 ADJ1 TOP VIEW NC 2 15 SHDN1 BYP1 1 16 ADJ1 OUT1 3 14 IN1 NC 2 15 SHDN1 OUT1 3 14 IN1 OUT1 4 17 13 IN1 OUT1 4 17 13 IN1 GND GND 5 12 IN2 GND 5 GND 12 IN2 OUT2 6 11 IN2 OUT2 6 11 IN2 OUT2 7 10 SHDN2 OUT2 7 10 SHDN2 BYP2 8 9 ADJ2 BYP2 8 9 ADJ2 MSE PACKAGE 16-LEAD PLASTIC MSOP DE PACKAGE 16-LEAD (4mm × 3mm) PLASTIC DFN TJMAX = 125°C (LT3029E/LT3029I/LT3029MP), θJA = 37°C/W, θJC: 5°C/W TO 10°C/W T TJMAX = 150°C (LT3029H), θJA = 37°C/W, θJC: 5°C/W TO 10°C/W JMAX = 125°C (LT3029E/LT3029I), θJA = 38°C/W , θJC = 4.3°C/W T EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB GND JMAX = 150°C (LT3029H), θJA = 38°C/W , θJC = 4.3°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB GND
orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3029EDE#PBF LT3029EDE#TRPBF 3029 16-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3029IDE#PBF LT3029IDE#TRPBF 3029 16-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3029HDE#PBF LT3029HDE#TRPBF 3029 16-Lead (4mm × 3mm) Plastic DFN –40°C to 150°C LT3029EMSE#PBF LT3029EMSE#TRPBF 3029 16-Lead Plastic MSOP –40°C to 125°C LT3029IMSE#PBF LT3029IMSE#TRPBF 3029 16-Lead Plastic MSOP –40°C to 125°C LT3029HMSE#PBF LT3029HMSE#TRPBF 3029 16-Lead Plastic MSOP –40°C to 150°C LT3029MPMSE#PBF LT3029MPMSE#TRPBF 3029 16-Lead Plastic MSOP –55°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3029EDE LT3029EDE#TR 3029 16-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3029IDE LT3029IDE#TR 3029 16-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3029HDE LT3029HDE#TR 3029 16-Lead (4mm × 3mm) Plastic DFN –40°C to 150°C LT3029EMSE LT3029EMSE#TR 3029 16-Lead Plastic MSOP –40°C to 125°C LT3029IMSE LT3029IMSE#TR 3029 16-Lead Plastic MSOP –40°C to 125°C LT3029HMSE LT3029HMSE#TR 3029 16-Lead Plastic MSOP –40°C to 150°C LT3029MPMSE LT3029MPMSE#TR 3029 16-Lead Plastic MSOP –55°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3029fb 2 For more information www.linear.com/LT3029 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
