Datasheet LT3030 (Analog Devices) - 10
Description | Dual 750mA/250mA Low Dropout, Low Noise, Micropower Linear Regulator |
Pages / Page | 22 / 10 — Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 657 Kb |
Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. OUT1 or OUT2 Minimum Input
LT3030
Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. OUT1 or OUT2 Minimum Input 10Hz to 100kHz Output Noise, 10Hz to 100kHz Output Noise, Voltage CBYP = 0pF CBYP = 100pF
2.50 VOUT1 = VOUT2 = 1.220V 2.25 2.00 IL = FULL LOAD 1.75 TAGE (V) 1.50 V V I OUT OUT L = 1mA 100µV/DIV 100µV/DIV 1.25 1.00 0.75 MINIMUM INPUT VOL 0.50 1ms/DIV 3030 G47 1ms/DIV 3030 G48 0.25 COUT = 10µF COUT = 10µF I I 0 L = FULL LOAD L = FULL LOAD –75 –50 –25 0 25 50 75 100 125 150 175 VOUT = 5V VOUT = 5V TEMPERATURE (°C) 3030 G46
10Hz to 100kHz Output Noise, 10Hz to 100kHz Output Noise, OUT1 Transient Response CBYP = 1000pF CBYP = 0.01µF CBYP = 0pF
VOUT DEVIATION 200mV/DIV VOUT VOUT 100µV/DIV 100µV/DIV LOAD CURRENT DEVIATION 500mA/DIV 1ms/DIV 3030 G49 1ms/DIV 3030 G50 200µs/DIV 3030 G51 COUT = 10µF COUT = 10µF V I I IN = 6V L = 100mA TO 750mA L = FULL LOAD IL = FULL LOAD C T V IN = 22µF J = 25°C OUT = 5V VOUT = 5V COUT = 22µF VOUT = 5V
OUT1 Transient Response OUT2 Transient Response OUT2 Transient Response CBYP = 0.01µF CBYP = 0pF CBYP = 0.01µF
VOUT DEVIATION VOUT DEVIATION VOUT DEVIATION 50mV/DIV 200mV/DIV 50mV/DIV LOAD CURRENT DEVIATION LOAD CURRENT DEVIATION LOAD CURRENT DEVIATION 500mA/DIV 100mA/DIV 100mA/DIV 20µs/DIV 3030 G52 200µs/DIV 3030 G53 20µs/DIV 3030 G54 VIN = 6V IL = 100mA TO 750mA VIN = 6V IL = 100mA TO 250mA VIN = 6V IL = 100mA TO 250mA CIN = 22µF TJ = 25°C CIN = 10µF TJ = 25°C CIN = 10µF TJ = 25°C COUT = 22µF VOUT = 5V COUT = 10µF VOUT = 5V COUT = 10µF VOUT = 5V 3030fa 10 For more information www.linear.com/LT3030 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
