Datasheet LT1617, LT1617-1 (Analog Devices) - 2
DescriptionMicropower Inverting DC/DC Converters in SOT-23
Pages / Page8 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL …
File Format / SizePDF / 146 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) ELECTRICAL CHARACTERISTICS The
LT1617/LT1617-1
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
ORDER PART VIN, SHDN Voltage ... 15V TOP VIEW NUMBER SW Voltage .. 36V SW 1 5 VIN LT1617ES5 NFB Voltage ... – 3V GND 2 LT1617ES5-1 Current into NFB Pin ... –1mA NFB 3 4 SHDN Junction Temperature ... 125°C S5 PACKAGE S5 PART MARKING Operating Temperature Range (Note 2) .. – 40°C to 85°C 5-LEAD PLASTIC SOT-23 Storage Temperature Range ... – 65°C to 150°C TJMAX = 125°C, θJA = 256°C/W LTKF Lead Temperature (Soldering, 10 sec).. 300°C LTKA Consult factory for Industrial and Military grade parts.
C. VIN = 1.2V, VSHDN = 1.2V unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage LT1617-1 1.0 V LT1617 1.2 V Quiescent Current Not Switching 20 30 µA VSHDN = 0V 1 µA FB Comparator Trip Point ● –1.205 –1.23 –1.255 V FB Comparator Hysteresis 8 mV Output Voltage Line Regulation 1.2V < VIN < 12V 0.05 0.1 %/V FB Pin Bias Current (Note 3) VNFB = –1.23V ● 1.3 2 2.7 µA Switch Off Time 400 ns Switch VCESAT ISW = 60mA (LT1617-1) 85 120 mV ISW = 300mA (LT1617) 250 350 mV Switch Current Limit LT1617-1 75 100 125 mA LT1617 300 350 400 mA SHDN Pin Current VSHDN = 1.2V 2 3 µA VSHDN = 5V 8 12 µA SHDN Input Voltage High 0.9 V SHDN Input Voltage Low 0.25 V Switch Leakage Current Switch Off, VSW = 5V 0.01 5 µA
Note 1:
Absolute Maximum Ratings are those values beyond which the life of a device may be impaired.
Note 2:
The LT1617 and LT1617-1 are guaranteed to meet specifications from 0°C to 70°C. Specifications over the – 40°C to 85°C operating temperature range are assured by design, characterization and correlation with statistical process controls.
Note 3:
Bias current flows out of the NFB pin. 2
