Datasheet LT3582, LT3582-5, LT3582-12 (Analog Devices) - 2
DescriptionBoost and Single Inductor Inverting DC/DC Converters with Optional I2C Programing and OTP
Pages / Page28 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 328 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT3582/LT3582-5/LT3582-12
V TOP VIEW IN Voltage ..6V SWP Voltage ...15V PP SCL SDA V GND SWN Voltage .. –16.5V 16 15 14 13 CA 1 12 SWP CAPP Voltage ..15V V 2 OUTN 17 11 CAPP CAPP-VOUTP Voltage .. –0.8V to 8V GND SWN 3 10 CAPP ICAPP-VOUTP ... ±300mA SWN 4 9 VOUTP VOUTP Voltage ...15V 5 6 7 8 VOUTN Voltage .. –16.5V INV RAMPP Voltage ..3V SHDN RAMPN RAMPP RAMPN Voltage ..3V UD PACKAGE 16-PIN (3mm × 3mm) PLASTIC QFN SHDN Voltage .. –0.5 to 6V TJMAX = 125°C, θJA = 68°C/W V EXPOSED PAD (PIN #17) IS GND, MUST BE SOLDERED TO PCB PP Voltage ...–0.2 to 16V SDA, CA, SCL Voltage .. –0.5 to 6V Operating Junction Temperature Range (Notes 3, 5) LT3582E .. –40°C to 125°C Storage Temperature Range .. –65°C to 150°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3582EUD#PBF LT3582EUD#TRPBF LDDB 16-Pin (3mm × 3mm) Plastic QFN –40°C to 125°C LT3582EUD-5#PBF LT3582EUD-5#TRPBF LDVG 16-Pin (3mm × 3mm) Plastic QFN –40°C to 125°C LT3582EUD-12#PBF LT3582EUD-12#TRPBF LDVH 16-Pin (3mm × 3mm) Plastic QFN –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 3.6V, VSHDN = VIN unless otherwise noted. (Note 3) Switching Regulator Characteristics SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN_MIN Minimum Operating Voltage l 2.4 2.475 2.55 V VIN_MAX Maximum Operating Voltage l 5.5 V IVIN VIN Quiescent Current Ramp Current Confi gured to 1μA, 325 450 μA SWOFF Bit Active IVIN_SHDN VIN Quiescent Current in Shutdown VSHDN = 0 0.01 0.5 μA ICAPP_SHDN CAPP Quiescent Current in Shutdown VSHDN = 0, VCAPP = 5.0V, VOUTP = 0V 0 0.5 μA TOFF_MINP Minimum Switch Off Time Boost Switch 100 ns TOFF_MINN Minimum Switch Off Time Inverting Switch 125 ns 3582512fb 2
