Datasheet LTC1622 (Analog Devices) - 3
DescriptionLow Input Voltage Current Mode Step-Down DC/DC Controller
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 198 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTC1622
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = 4.2V SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
PDRV tr Gate Drive Rise Time CLOAD = 3000pF 80 140 ns PDRV tf Gate Drive Fall Time CLOAD = 3000pF 100 140 ns ∆VSENSE(MAX) Maximum Current Sense Voltage ● 80 110 140 mV
Note 1:
Note 3:
The LTC1622 is tested in a feedback loop that servos VFB to the of a device may be impaired. feedback point for the error amplifier (VITH = 0.8V).
Note 2:
TJ is calculated from the ambient temperature TA and power
Note 4:
Dynamic supply current is higher due to the gate charge being dissipation PD according to the following formula: delivered at the switching frequency. LTC1622CS8; TJ = TA + (PD • 150°C/W), LTC1622CMS8; TJ = TA + (PD • 250°C/W)
W U TYPICAL PERFORMANCE CHARACTERISTICS Shutdown Current Maximum Current Sense Voltage vs Supply Voltage RUN/SS Current vs Supply Voltage vs Duty Cycle
45 3.50 110 VIN = 4.2V 40 100 3.00 µA) 35 µA) 90 30 UNSYNC 80 2.50 25 70 20 2.00 60 15 TRIP VOLTAGE (mV) SHUTDOWN CURRENT ( 10 50 SOFT-START CURRENT ( 1.50 5 40 0 1.00 30 2 3 4 5 6 7 8 9 10 2 3 4 5 6 7 8 9 10 20 30 40 50 60 70 80 90 100 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) DUTY CYCLE (%) 1622 G01 1622 G02 1622 G03
Normalized Oscillator Frequency Reference Voltage Undervoltage Lockout Voltage vs Temperature vs Temperature vs Temperature
10.0 0.810 2.10 VIN = 4.2V VIN = 4.2V 7.5 0.805 2.05 5.0 0.800 2.00 2.5 0.795 1.95 0 0.790 1.90 –2.5 0.785 1.85 –5.0 REFERENCE VOLTAGE (V) NORMALIZED FREQUENCY (%) 0.780 1.80 –7.5 UNDERVOLTAGE LOCKOUT VOLTAGE (V) –10.0 0.775 1.75 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 1622 G04 1622 G05 1622 G06 3
