Datasheet LTC3122 (Analog Devices) - 7
Description15V, 2.5A Synchronous Step-Up DC/DC Converter with Output Disconnect
Pages / Page26 / 7 — pin FuncTions. SW (Pin 1):. VCC (Pin 5):. PGND (Pins 2, 13):. RT (Pin …
File Format / SizePDF / 512 Kb
pin FuncTions. SW (Pin 1):. VCC (Pin 5):. PGND (Pins 2, 13):. RT (Pin 6):. must be. IN (Pin 3):. VC (Pin 7):. PWM/SYNC (Pin 4):
pin FuncTions SW (Pin 1): VCC (Pin 5): PGND (Pins 2, 13): RT (Pin 6): must be IN (Pin 3): VC (Pin 7): PWM/SYNC (Pin 4):
LTC3122
Switch Pin. Connect an inductor from this
VCC (Pin 5):
VCC Regulator Output. Connect a low-ESR pin to VIN. Keep PCB trace lengths as short and wide as filter capacitor of at least 4.7µF from this pin to GND to possible to reduce EMI and voltage overshoot. When VOUT provide a regulated rail approximately equal to the lower of ≥ VIN + 2V, an internal anti-ringing resistor is connected VIN and 4.25V. When VOUT is higher than VIN, and VIN falls between SW and VIN after the inductor current has dropped below 3V, VCC will regulate to the lower of approximately to near zero, to minimize EMI. The anti-ringing resistor is VOUT and 4.25V. A UVLO event occurs if VCC drops below also activated in shutdown and during the sleep periods 1.6V. Switching is inhibited, and a soft-start is initiated of Burst Mode operation. when VCC returns above 1.7V.
PGND (Pins 2, 13):
Power Ground. When laying out your
RT (Pin 6):
Frequency Adjust Pin. Connect an external PCB, provide a short, direct path between PGND and the resistor (RT) from this pin to SGND to program the oscil- output capacitor and tie directly to the ground plane. The lator frequency according to the formula: exposed pad is ground and
must be
soldered to the PCB R ground plane for rated thermal performance. T = 57.6/ƒOSC where ƒ
V
OSC is in MHz and RT is in kΩ.
IN (Pin 3):
Input Supply Pin. The device is powered from V
VC (Pin 7):
Error Amplifier Output. A frequency compen- IN unless VOUT exceeds VIN and VIN is less than 3V. Place a low ESR ceramic bypass capacitor of at least 4.7µF from sation network is connected to this pin to compensate V the control loop. See Compensating the Feedback Loop IN to PGND. X5R and X7R dielectrics are preferred for their superior voltage and temperature characteristics. section for guidelines.
PWM/SYNC (Pin 4):
Burst Mode Operation Select and
FB (Pin 8):
Feedback Input to the Error Amplifier. Connect Oscillator Synchronization.
Do not leave this pin floating.
the resistor divider tap to this pin. Connect the top of the divider to VOUT and the bottom of the divider to SGND. • PWM/SYNC = High. Disable Burst Mode Operation and The output voltage can be adjusted from 2.2V to 15V ac- maintain low noise, constant frequency operation. cording to this formula: • PWM/SYNC = Low. The converter operates in Burst VOUT = 1.202V • (1 + R1/R2) Mode operation, independent of load current.
SD (Pin 9):
Logic Controlled Shutdown Input. Bringing this • PWM/SYNC = External CLK. The internal oscillator is pin above 1.6V enables normal, free-running operation, synchronized to the external CLK signal. Burst Mode forcing this pin below 0.25V shuts the LTC3122 down, with operation is disabled. A clock pulse width between quiescent current below 1μA.
100ns and 2µs is required to synchronize the oscillator.
SGND (Pin 10):
Signal Ground. When laying out a PC An external resistor
must be
connected between RT board, provide a short, direct path between SGND and and GND to program the oscillator slightly below the the (–) side of the output capacitor. desired synchronization frequency.
V
In non-synchronized applications, repeated clocking of
OUT (Pin 11):
Output Voltage Sense and the Source of the Internal Synchronous Rectifier MOSFET. Driver bias the PWM/SYNC pin to affect an operating mode change is derived from V is supported with these restrictions: OUT. Connect the output filter capacitor from VOUT to PGND, as close to the IC as possible. A • Boost Mode (VOUT > VIN): IOUT <500µA: ƒPWM/SYNC ≤ minimum value of 10µF ceramic is recommended. VOUT 100Hz, IOUT ≥ 500µA: ƒPWM/SYNC ≤ 5kHz is disconnected from VIN when SD is low. • Buck Mode (VOUT < VIN): IOUT <5mA: ƒPWM/SYNC ≤ 5Hz,
CAP (Pin 12):
Serves as the Low Reference for the Syn- IOUT ≥ 5mA: ƒPWM/SYNC ≤ 5kHz chronous Rectifier Gate Drive. Connect a low ESR filter capacitor (typically 100nF) from this pin to VOUT to provide an elevated ground rail, approximately 5.6V below VOUT, used to drive the synchronous rectifier. 3122fa For more information www.linear.com/LTC3122 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
