Datasheet LTC3527, LTC3527-1 (Analog Devices) - 2
DescriptionDual 800mA/400mA, 1.2MHz/2.2MHz Synchronous Step-Up DC/DC Converters
Pages / Page22 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 373 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC3527/LTC3527-1
TOP VIEW VIN, VIN1, VIN2 Voltage ...–0.3V to 6V SW1, SW2 Voltage (DC) .. –0.3V to 6V IN PGOOD1 V GND PGOOD2 (Pulsed < 100ns) ... –0.3V to 7V 16 15 14 13 SHDN1, SHDN2, FB1, FB2 Voltage ...–0.3V to 6V SHDN1 1 12 SHDN2 VOUT1, VOUT2 ..–0.3V to 6V FB1 2 17 11 FB2 MODE, FSEL, PGOOD1, PGOOD2 ... –0.3V to 6V PGND MODE 3 10 FSEL Operating Temperature (Notes 2, 5) ...–40°C to 85°C VIN1 4 9 VIN2 Junction Temperature ... 125°C 5 6 7 8 Storage Temperature Range ...–65°C to 125°C OUT1 SW1 SW2 OUT2 V V UD PACKAGE 16-LEAD (3mm s 3mm) PLASTIC QFN TJMAX = 125°C, θJA = 68°C/W EXPOSED PAD (PIN 17) IS PGND, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3527EUD#PBF LTC3527EUD#TRPBF LDDK 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C LTC3527EUD-1#PBF LTC3527EUD-1#TRPBF LCXP 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3527EUD LTC3527EUD#TR LDDK 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C LTC3527EUD-1 LTC3527EUD-1#TR LCXP 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the full operating temperature range, –40°C to 85°C. VIN = VIN1 = VIN2 = 1.2V, VOUT1 = VOUT2 = 3.3V, TA = 25°C, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Start-Up Voltage ILOAD = 1mA 0.7 0.88 V Output Voltage Adjust Range VOUT1 l 1.7 5.25 V VOUT1 1.6 5.25 V VOUT2 l 1.7 5.25 V VOUT2 1.6 5.25 V Line Regulation VIN = 1V to 5V 0.005 %/V Feedback Voltage FB1, FB2 l 1.176 1.20 1.224 V Feedback Input Current FB1, FB2 VFB1,2 = 1.20V 1 50 nA Quiescent Current: Shutdown VSHDN1 = VSHDN2 = 0V, Not Including Switch 0.1 2 μA Leakage, VOUT1 = VOUT2 = 0V Quiescent Current: Burst Mode Operation Measured on VOUT, VFB1 = VFB2 = 1.5V 12 μA Quiescent Current: Active VFB1 = VFB2 > 1.2V (Note 3) 500 900 μA NMOS Switch Leakage Current (LTC3527) VSW1,2 = 5V, SHDN1,2 = 0V 0.1 10 μA 35271fc 2
