Datasheet LTC3700 (Analog Devices) - 3
DescriptionConstant Frequency Step-Down DC/DC Controller with LDO Regulator
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications that apply over …
File Format / SizePDF / 221 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications that apply over the full operating temperature
ELECTRICAL CHARACTERISTICS The denotes specifications that apply over the full operating temperature
LTC3700
denotes specifications that apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = VIN2 = 4.2V unless otherwise specified. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS LDO Regulator
VIN2 Input Voltage 2.4 6 V Input DC Supply Current Typicals at VIN2 = 4.2V Normal Operation with Buck Enabled 2.4V ≤ VIN2 ≤ 6V 50 100 µA Normal Operation with Buck Undervoltage 2.4V ≤ VIN2 ≤ 6V 100 150 µA Shutdown with Buck Enabled 2.4V ≤ VIN2 ≤ 6V, VITH/RUN = 0V 0 1 µA Shutdown with Buck Undervoltage 2.4V ≤ VIN2 ≤ 6V, VITH/RUN = 0V 8 24 µA Regulated Feedback Voltage 0°C ≤ TA ≤ 70°C, ILDO = 1mA ● 0.780 0.800 0.830 V –40°C ≤ TA ≤ 85°C, ILDO = 1mA ● 0.765 0.800 0.835 V Output Voltage Line Regulation (Unity-Gain Feedback) With Buck Enabled 2.65V ≤ VIN ≤ 9.8V 0.05 mV/V With Buck Enabled 2.4V ≤ VIN2 ≤ 6V, ILDO = 1mA 4 mV/V With Buck Undervoltage 2.4V ≤ VIN2 ≤ 6V, ILDO = 1mA 4 mV/V Output Voltage Load Regulation 1mA ≤ ILOAD ≤ 150mA 0.06 0.12 mV/mA VFB2 Input Current 0 10 nA LDO Short-Circuit Current VLDO = 0V 150 200 mA LDO Dropout VIN2 = 3.3V, ILDO = 150mA 270 mV VIN2 = 6V, ILDO = 150mA 170 mV Overtemperature Trip Point (Note 7) 150 °C Overtemperature Hysteresis (Note 7) 5 °C
PGOOD
Feedback Voltage PGOOD Threshold (Note 8) PGOOD High-to-Low VFB or VFB2 Falling – 12 – 7.5 % VFB or VFB2 Rising 7.5 12 % PGOOD Low-to-High VFB or VFB2 Rising – 10 – 5.0 % VFB or VFB2 Falling 5.0 10 % PGOOD On-Resistance VITH/RUN = 0V, VIN = VIN2 = 4.2V, VPGOOD = 100mV 135 180 Ω
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 4:
Dynamic supply current is higher due to the gate charge being of a device may be impaired. delivered at the switching frequency.
Note 2:
The LTC3700 is guaranteed to meet specifications from␣ 0°C␣ to
Note 5:
The LTC3700 is tested in a feedback loop that servos VFB to the 70°C. Specifications over the –40°C to 85°C operating temperature range output of the error amplifier. are assured by design, characterization and correlation with statistical
Note 6:
Peak current sense voltage is reduced dependent on duty cycle to process controls. a percentage of value as given in Figure 2.
Note 3:
TJ is calculated from the ambient temperature TA and power
Note 7:
Guaranteed by design; not tested in production. dissipation PD according to the following formula:
Note 8:
PGOOD values are expressed as a percentage difference from the TJ = TA + (PD • θJA°C/W) respective “Regulated Feedback Voltage” as given in the table. 3700f 3
