Datasheet LTC3823 (Analog Devices) - 4
DescriptionFast No RSENSE Step-Down Synchronous DC/DC Controller with Differential Output Sensing, Tracking and PLL
Pages / Page26 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 315 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC3823
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 15V unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS PGOOD Output
ΔVFBH PGOOD Upper Threshold VFB Rising 8 11 14 % ΔVFBL PGOOD Lower Threshold VFB Falling –8 –11 –14 % ΔVFB(HYS) PGOOD Hysteresis VFB Returning 1.5 3 % VPGL PGOOD Low Voltage IPGOOD = 5mA 0.15 0.4 V
Differential Sensing Amplifi er
ADA Gain l 0.9965 1.000 1.0035 V/V R + IN Input Resistance Measured at VOUTSENSE Input 80 kΩ V + OS Input Offset Voltage VOUTSENSE = VDIFFOUT = 1.5V, 2 mV IDIFFOUT = 1mA PSRROA Power Supply Rejection Ratio 6V < VIN < 30V 90 dB ICL Maximum Output Current 3 mA VOUT(MAX) Maximum Output Voltage IDIFFOUT = 300μA l 3.775 4 V GBW Gain Bandwidth Product IDIFFOUT = 1mA 3.5 MHz
Thermal Shutdown
TSD Shutdown Temperature Rising 170 °C THYST Thermal Hysteresis 15 °C
Note 1:
Note 3:
The LTC3823 is tested in a feedback loop that servos VFB to may cause permanent damage to the device. Exposure to any Absolute achieve a specifi ed error amplifi er output voltage (ITH). Maximum Rating condition for extended periods may affect device
Note 4:
The LTC3823E is guaranteed to meet performance specifi cations reliability and lifetime. from 0°C to 85°C. Specifi cations over the –40°C to 85°C operating
Note 2:
TJ is calculated from the ambient temperature TA and power temperature range are assured by design, characterization and correlation dissipation PD according to the following formulas: with statistical process controls. The LTC3823I is guaranteed over the full LTC3823GN: T –40°C to 85°C operating temperature range. J = TA + (PD • 80°C/W) LTC3823UH: TJ = TA + (PD • 34°C/W)
TYPICAL PERFORMANCE CHARACTERISTICS Current Sense Threshold vs ITH Voltage On-Time vs ION Current On-Time vs VON Voltage
300 10000 800 V V I RNG = 2V ON = 0V ION = 60μA 250 700 1.4V 200 600 1V 150 1000 0.7V 500 100 400 50 0.5V ON-TIME (ns) ON-TIME (ns) 300 0 100 200 –50 CURRENT SENSE THRESHOLD (mV) –100 100 –150 10 0 0 0.5 1 1.5 2 2.5 0 10 20 30 40 50 60 70 80 90 100 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 ITH VOLTAGE (V) ION CURRENT (μA) VON VOLTAGE (V) 2823 G01 3823 G02 3823 G03 3823fd 4
