Datasheet LTC3833 (Analog Devices)
DescriptionFast Accurate Step-Down DC/DC Controller with Differential Output Sensing
Pages / Page36 / 1 — FEATURES. DESCRIPTION. Wide VIN Range: 4.5V to 38V. VOUT Range: 0.6V to …
File Format / SizePDF / 530 Kb
FEATURES. DESCRIPTION. Wide VIN Range: 4.5V to 38V. VOUT Range: 0.6V to 5.5V. Output Accuracy: ±0.25% at 25°C and ±0.67%
Datasheet LTC3833 Analog Devices
LTC3833 Fast Accurate Step-Down DC/DC Controller with Differential Output Sensing
FEATURES DESCRIPTION
n
The LTC®3833 is a synchronous step-down DC/DC n
switching regulator controller targeted for high power n
applications. It drives all N-channel power MOSFETs. The
over Temperature
controlled on-time valley current mode architecture allows n
Differential Output Sensing Allowing Up to 500mV
for both fast transient response and constant frequency
Line Loss
switching in steady-state operation, independent of VIN, n
Fast Load Transient Response
VOUT and load current. n
tON(MIN) = 20ns, tOFF(MIN) = 90ns
Differential output voltage sensing along with a precision n
Controlled On-Time Valley Current Mode
internal reference combine to offer ±0.67% output regula-
Architecture
tion and the ability to correct for up to ±500mV variations n
Frequency Programmable from 200kHz to 2MHz
in the output terminals due to line losses. The operating
and Synchronizable to External Clock
frequency can be programmed from 200kHz to 2MHz with n RSENSE or Inductor DCR Current Sensing an external resistor and can be synchronized to an external n Overvoltage Protection and Current Limit Foldback clock for noise and EMI sensitive applications. n Power Good Output Voltage Monitor n Output Tracking or Adjustable Soft-Start Very low tON and tOFF times allow for near 0% and near n External V 100% duty cycles, respectively. Programmable soft-start or CC Input for Bypassing Internal LDO n 20-Pin QFN (3mm × 4mm) and TSSOP Packages output voltage tracking is available. Safety features include output overvoltage protection, programmable current limit
with foldback, and a power good output signal. n L, LT, LTC, LTM, OPTI-LOOP, PolyPhase, µModule, Linear Technology and the Linear logo Distributed Power Systems are registered trademarks and Hot Swap, No RSENSE and UltraFast are trademarks of Linear n Point-of-Load Converters Technology Corporation. All other trademarks are the property of their respective owners. Protected by U.S. Patents, including 5481178, 5487554, 6580258, 6304066, 6476589, n Computing Systems 6774611. n Datacomm Systems
TYPICAL APPLICATION 1.5V, 20A, 300kHz High Current Step-Down Converter
INTVCC
Efficiency
V V RNG VIN IN 4.5V TO 14V 100 VOUT 180µF PULSE-SKIPPING 100k SENSE– MODE PGOOD 90 SENSE+ 0.1µF RUN TG 3.24k LTC3833 80 FORCED 0.1µF SW CONTINUOUS 0.47µH VOUT MODE TRACK/SS BOOST 1.5V 70 470pF 20A 10k 0.1µF 15k ITH INTVCC INTVCC 330µF EFFICIENCY (%) 60 137k 4.7µF ×2 RT 10k EXTV 50 CC BG VIN = 12V SGND PGND VOUT = 1.5V 40 300kHz MODE/PLLIN 0.1 1 10 100 V + OSNS LOAD CURRENT (A) – 3833 TA01a VOSNS 3833 TA01b 3833f 1
