Datasheet LTC3109 (Analog Devices) - 3
DescriptionAuto-Polarity, Ultralow Voltage Step-Up Converter and Power Manager
Pages / Page24 / 3 — elecTrical characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 424 Kb
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
LTC3109
denotes the specifications which apply over the full operating junction temperature range, otherwise specifications are for TA = 25°C (Note 2). VAUX = 5V unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Start-Up Voltage Using 1:100 Transformer Turns Ratio, VAUX = 0V ±30 ±50 mV No-Load Input Current Using 1:100 Transformer Turns Ratios, 6 mA VIN = 30mV, VOUT2_EN = 0V, All Outputs Charged and in Regulation Input Voltage Range Using 1:100 Transformer Turns Ratios l VSTARTUP ±500 mV Output Voltage VS1 = VS2 = GND l 2.30 2.350 2.40 V VS1 = VAUX, VS2 = GND l 3.234 3.300 3.366 V VS1 = GND, VS2 = VAUX l 4.018 4.100 4.182 V VS1 = VS2 = VAUX l 4.875 5.000 5.10 V VAUX Quiescent Current No Load, All Outputs Charged 7 10 µA VAUX Clamp Voltage Current Into VAUX = 5mA l 5.0 5.25 5.55 V VOUT Quiescent Current VOUT = 3.3V, VOUT2_EN = 0V 0.2 µA VOUT Current Limit VOUT = 0V l 6 15 26 mA N-Channel MOSFET On-Resistance C2B = C2A = 5V (Note 3) Measured from VINA or 0.35 Ω SWA, VINB or SWB to GND LDO Output Voltage 0.5mA Load On VLDO l 2.134 2.2 2.30 V LDO Load Regulation For 0mA to 2mA Load 0.5 1 % LDO Line Regulation For VAUX from 2.5V to 5V 0.05 0.2 % LDO Dropout Voltage ILDO = 2mA l 100 200 mV LDO Current Limit VLDO = 0V l 5 12 mA VSTORE Leakage Current VSTORE = 5V 0.1 0.3 µA VSTORE Current Limit VSTORE = 0V l 6 15 26 mA VOUT2 Leakage Current VOUT2 = 0V, VOUT2_EN = 0V 50 nA VS1, VS2 Threshold Voltage l 0.4 0.85 1.2 V VS1, VS2 Input Current VS1 = VS2 = 5V 1 50 nA PGOOD Threshold (Rising) Measured Relative to the VOUT Voltage –7.5 % PGOOD Threshold (Falling) Measured Relative to the VOUT Voltage –9 % PGOOD VOL Sink Current = 100µA 0.12 0.3 V PGOOD VOH Source Current = 0 2.1 2.2 2.3 V PGOOD Pull-Up Resistance 1 MΩ VOUT2_EN Threshold Voltage VOUT2_EN Rising l 0.4 1.0 1.3 V VOUT2_EN Threshold Hysteresis 100 mV VOUT2_EN Pull-Down Resistance 5 MΩ VOUT2 Turn-On Time 0.5 µs VOUT2 Turn-Off Time (Note 3) 0.15 µs VOUT2 Current Limit VOUT = 3.3V l 0.2 0.3 0.5 A VOUT2 Current Limit Response Time (Note 3) 350 ns VOUT2 P-Channel MOSFET On-Resistance VOUT = 5V (Note 3) 1.0 Ω
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings 0°C to 85°C junction temperature. Specifications over the –40°C to may cause permanent damage to the device. Exposure to any Absolute 125°C operating junction temperature range are assured by design, Maximum Rating condition for extended periods may affect device characterization and correlation with statistical process controls. The reliability and lifetime. LTC3109I is guaranteed over the full –40°C to 125°C operating junction
Note 2:
The LTC3109 is tested under pulsed load conditions such that temperature range. Note that the maximum ambient temperature T is determined by specific operating conditions in conjunction with J ≈ TA. The LTC3109E is guaranteed to meet specifications from 3109fb For more information www.linear.com/LTC3109 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Typical Application Related Parts
