Datasheet LTC4123 (Analog Devices) - 10
DescriptionLow Power Wireless Charger for Hearing Aids
Pages / Page18 / 10 — operaTion. Table 1. CHRG Pin Status Summary. CHRG. Blink Frequency. …
operaTion. Table 1. CHRG Pin Status Summary. CHRG. Blink Frequency. Charge Status. Operation without Wireless Power
operaTion Table 1 CHRG Pin Status Summary CHRG Blink Frequency Charge Status Operation without Wireless Power
LTC4123
operaTion
charge resistance of a Zinc-Air battery is higher than a
NiMH battery and therefore the battery voltage of Zinc-Air
rises significantly. An LED connected to CHRG will blink On (Pull-Down) Charging complete fast indicating a battery fault condition. Blink Slow (0.8Hz) Charging If the LTC4123 is in UVCL mode at the beginning of the Blink Fast (6Hz) Fault-No Charging; Temperature Fault/ charge cycle (typically 3 seconds after power is first ap- Battery in Reverse/Zinc-Air Battery Present/UVCL at the beginning of plied), it is unable to provide full charge current to perform charge cycle Zinc-Air battery detection. In this case, a battery fault will Off (High Impedance) No power/No Charging be indicated at CHRG (blink fast). Adjust the magnetic coupling between the receive and transmit coils to restart
the charging cycle. LTC4123 can be powered by connecting a DC voltage When a battery is inserted in reverse or the die temperature source to the VCC pin instead of receiving power wirelessly is above 70˚C or below –5˚C, an LED connected to CHRG through the ACIN pin. Ground the ACIN pin if an input will blink fast. Table 1 summarizes the four different pos- supply voltage is connected to VCC. sible states of the CHRG pin when the charger is active. 4123fa 10 For more information www.linear.com/LTC4123
