Datasheet LT3474, LT3474-1 (Analog Devices) - 2
DescriptionStep-Down 1A LED Driver
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
File Format / SizePDF / 226 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT3474/LT3474-1
VIN Pin ..(–0.3V), 36V BIAS Pin ..25V TOP VIEW BOOST Pin Voltage ...51V BOOST above SW Pin ...25V DNC* 1 16 DNC* OUT 2 15 GND OUT, LED Pins (LT3474) ..15V LED 3 14 PWM OUT, LED Pins (LT3474-1) ...26V V 4 IN 17 13 VADJ PWM Pin ...10V SW 5 12 VC VADJ Pin ...6V BOOST 6 11 REF VC, REF, RT Pins ..3V BIAS 7 10 SHDN SHDN Pin ...VIN GND 8 9 RT BIAS Pin Current ...1A FE PACKAGE Maximum Junction Temperature (Note 2)... 125°C 16-LEAD PLASTIC TSSOP Operating Temperature Range (Note 3) θJC = 8°C/W, θJA = 40°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB LT3474E, LT3474E-1 .. –40°C to 85°C *DO NOT CONNECT EXTERNAL CIRCUITRY TO THESE PINS. LT3474I, LT3474I-1 .. –40°C to 125°C Storage Temperature Range ... –65°C to 150°C Lead Temperature (Soldering, 10 sec) .. 300°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3474EFE#PBF LT3474EFE#TRPBF 3474EFE 16-Lead TSSOP –40°C to 85°C LT3474IFE#PBF LT3474IFE#TRPBF 3474IFE 16-Lead TSSOP –40°C to 125°C LT3474EFE-1#PBF LT3474EFE-1#TRPBF 3474EFE-1 16-Lead TSSOP –40°C to 85°C LT3474IFE-1#PBF LT3474IFE-1#TRPBF 3474IFE-1 16-Lead TSSOP –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 12V, VBOOST = 16V, VOUT = 4V unless otherwise noted (Note 3). PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage l 3.5 4 V Input Quiescent Current Not Switching 2.6 4 mA Shutdown Current SHDN = 0.3V, VBOOST = 0V, VOUT = 0V 0.01 2 μA LED Pin Current VADJ Tied to VREF 0.98 1 1.02 A l 0.968 1.025 A VADJ Tied to VREF/5 0.193 0.2 0.207 A l 0.186 0.210 A REF Voltage l 1.23 1.25 1.265 V 3474fd 2
