Datasheet LT3595 (Analog Devices) - 3
Description16 Channel Buck Mode LED Driver
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 382 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT3595
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C, VIN = 45V, VCC = 3.3V, PWM =
S
H
D
N =
O
P
E
N
L
E
D = 3.3V, RSET = 75k
Ω
, GND = 0V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Operating Voltage 4.5 V VCC Operating Voltage 3 5.5 V VCC Input Under Voltage Lockout 2.6 2.9 V IVIN Quiescent Current ON, No Switching VIN = 45V 0.25 mA IVIN Quiescent Current in Shutdown VIN = 45V, ⎯S⎯H⎯D⎯N = 0V 15 40 μA IVCC Quiescent Current ON, No Switching VCC = 3.3V 17 mA IVCC Quiescent Current in Shutdown VCC = 3.3V, ⎯S⎯H⎯D⎯N = 0V 3 10 μA IL1-16 Output Current Accuracy RSET = 75.0kΩ 18.4 20 21.6 mA Switching Frequency 1.6 2 2.4 MHz Maximum Duty Cycle ● 78 83 % Switch Current Limit ● 90 120 150 mA Switch VCESAT ISW1-16 = 50mA 450 mV Switch Leakage Current VSW1-16 = 45V 0.1 6 μA Schottky Forward Drop ISCHOTTKY = 50mA 0.8 V Schottky Leakage Current VIN = 45V, VSW1-16 = 0.7V, ⎯S⎯H⎯D⎯N = 0V 0.1 4 μA ⎯S⎯H⎯D⎯N, PWM1-16 Input Low Voltage 0.4 V ⎯S⎯H⎯D⎯N, PWM1-16 Input High Voltage 1.6 V ⎯S⎯H⎯D⎯N Pin Bias Current ⎯S⎯H⎯D⎯N = 3.3V 35 μA PWM1-16 Pin Bias Current PWM1-16 = 3.3V 0.1 1 μA ⎯O⎯P⎯E⎯N⎯L⎯E⎯D Pin Voltage VCC = 3.3V, I⎯O⎯P⎯E⎯N⎯L⎯E⎯D = 200μA 0.12 V ⎯O⎯P⎯E⎯N⎯L⎯E⎯D Pin Input Leakage Current ⎯O⎯P⎯E⎯N⎯L⎯E⎯D = 3.3V 0.1 1 μA
Note 1:
Note 2:
The LT3595 is guaranteed to meet performance specifi cations may cause permanent damage to the device. Exposure to any Absolute from 0°C to 85°C junction temperature. Specifi cations over the –40°C Maximum Rating condition for extended periods may affect device to 85°C operating junction temperature range are assured by design, reliability and lifetime. characterization and correlation with statistical process controls. 3595f 3
