Datasheet LT3595A (Analog Devices) - 10
Description16 Channel Buck Mode LED Driver
Pages / Page16 / 10 — APPLICATIONS INFORMATION. Open LED Detection. Table 2. Recommended Output …
File Format / SizePDF / 392 Kb
APPLICATIONS INFORMATION. Open LED Detection. Table 2. Recommended Output Capacitor Values (VLED = 3.5V). # LEDs. COUT (μF)
APPLICATIONS INFORMATION Open LED Detection Table 2 Recommended Output Capacitor Values (VLED = 3.5V) # LEDs COUT (μF)
LT3595A
string depends on the number of LEDs and can vary from
Open LED Detection
0.47μF to 1μF. Refer to Table 2 for proper output capacitor The LT3595A detects an open LED on any channel and selection. reports it to the OPENLED pin. The fault also reports dur-
ing startup until the output voltage and LED current are
# LEDs COUT (μF)
in regulation. Therefore, it can also be used as a “power 3-10 0.47 ok” signal. 1-2 1
Programming LED Current Table 3. Recommended Ceramic Capacitor Manufacturers
The set resistor (RSET in the Block Diagram) controls Taiyo Yuden 408-573-4150 the LED current in all sixteen channels. LED current as www.t-yuden.com a function of the RSET resistance is shown in the Typical TDK 847-803-6100 Performance Characteristics. Common values for LED cur- www.component.tdk.com rent and their required resistor values are listed in Table 4. Murata 770-436-1300 Since resistor error directly translates to LED current error, www.murata.com precision resistors are preferred (1% is recommended). Kemet 800-533-1992 www.kemet.com The maximum allowed resistor value is 150k. Table 3 shows a list of several ceramic capacitor manufac-
Table 4. LED Current vs RSET Resistance
turers. Consult the manufacturers for detailed information
RSET (k
Ω
) ILED (mA)
on their entire selection of ceramic parts. 150 10 75.0 20 49.9 30 37.4 40 30.1 50 3595af 10
