Datasheet LT3596 (Analog Devices) - 2
Description60V Step-Down LED Driver
Pages / Page22 / 2 — (Note 1). LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. PACKAGE …
(Note 1). LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION. TEMPERATURE RANGE
(Note 1) LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3596 absoluTe MaxiMuM raTings pin conFiguraTion
(Note 1)
Input Voltage (VIN), EN/UVLO ..60V TOP VIEW BOOST ...80V BOOST Pin Above SW Pin ... 25V V IN V IN SW BOOST DA 51 50 48 46 44 LED1-3, VOUT ..42V 43 NC BIAS, FAULT ...25V FB 2 VREF, RT, ISET1-3, TSET, CTRLM ...3V 41 NC FB, CTRL1-3, PWM1-3, SYNC ..6V EN/UVLO 4 Operating Temperature Range 39 NC (Notes 2, 3) .. –40°C to 125°C TSET 6 VREF 7 37 BIAS Maximum Junction Temperature .. 125°C Storage Temperature Range .. –65°C to 150°C 53 GND 9 GND 35 NC 34 NC NC 11 33 CTRL1 NC 12 32 CTRL2 CTRLM 13 31 CTRL3 ISET1 14 30 PWM1 ISET2 15 29 PWM2 ISET3 16 28 PWM3 RT 17 27 SYNC 18 19 20 21 22 23 24 25 26 T NC NC NC NC V OUT LED1 LED2 LED3 FAUL UHG PACKAGE VARIATION: UHG52 (39) 52-LEAD (5mm s 8mm) PLASTIC QFN TJMAX = 125°C, θJA = 32°C/W EXPOSED PAD (PIN 53) IS GND, MUST BE SOLDERED TO PCB orDer inForMaTion
LT3596EUHG#PBF LT3596EUHG#TRPBF 3596 52-Lead (5mm × 8mm) Plastic QFN –40°C to 125°C LT3596IUHG#PBF LT3596IUHG#TRPBF 3596 52-Lead (5mm × 8mm) Plastic QFN –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3596fa Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Typical Application Related Parts
