LT3746 elecTrical characTerisTics Note 1: Stresses beyond those listed under Absolute Maximum Ratings SCKO/SDO/LDO loading capacitance, and PWMCK clock frequency; its may cause permanent damage to the device. Exposure to any Absolute test condition is VCC = 3.3V, fSCKI = 30MHz, CSCKO = CSDO = CLDO = 27pF, Maximum Rating condition for extended periods may affect device fPWMCK = 409.6KHz. reliability and lifetime. Note 5: The SYNC frequency must be higher than the RT programmed Note 2: The LT3746E is guaranteed to meet performance specifications oscil ator frequency, and is suggested to be around 20% higher. from 0°C to 125°C junction temperature. Specifications over the –40°C Any SYNC frequency higher than the suggested value may introduce to 125°C operating junction temperature range are assured by design, sub-harmonic oscil ation in the converter due to insufficient slope characterization and correlation with statistical process controls. The compensation. See Application Information section. LT3746I is guaranteed over the full –40°C to 125°C operating junction Note 6: The Current Mismatch between Channels is calculated as temperature range. Equation 1 in Table 1. Note 3: This IC includes thermal shutdown protection that is intended Note 7: The Current Mismatch between Devices is calculated as to protect the device during momentary overload conditions. Junction Equations 2 and 3 in Table 1. temperature will exceed 125°C when thermal shutdown protection is Note 8: The LED Current Line Regulation is calculated as Equation 4 in active. Continuous operation above the specified maximum operating Table 1. junction temperature may impair device reliability. Note 9: The LED Current Load Regulation is calculated as Equation 5 in Note 4: The VCC supply current with LED channel on highly depends on Table 1. the LED current setting and LEDxx pin voltage; its test condition is R Note 10: The specifications of single-ended input SI apply to SCKI, SDI, ISET = 60.4k, REGDC = 0x3F, REGGS = 0xFFF, VISP = VISN = 5V, V and LDI pins; the specifications of single-ended output SO apply to LEDxx = 0.5V. The VCC supply current with serial data interface on highly depends on V SCKO, SDO, and LDO pins. CC supply voltage, serial data interface clock frequency, 3746fa 6 For more information www.linear.com/3746 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Pin Functions Block Diagram Applications Information Typical Application Related Parts
