Datasheet AD4000, AD4004 (Analog Devices) - 5
Description16-Bit, 2 MSPS/1 MSPS, Precision, Pseudo Differential, SAR ADCs
Pages / Page34 / 5 — Data Sheet. AD4000/AD4004. Parameter. Test Conditions/Comments. Min. Typ. …
Data Sheet. AD4000/AD4004. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD4000/AD4004 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 7 link to page 12
Power Dissipation VDD = 1.8 V, VIO = 1.8 V, VREF = 5 V 10 kSPS, high-Z mode disabled 70 µW 1 MSPS, high-Z mode disabled 7 8.2 mW 2 MSPS, high-Z mode disabled 14 16 mW 1 MSPS, high-Z mode enabled 8 9.9 mW 2 MSPS, high-Z mode enabled 16 19 mW VDD Only 2 MSPS, high-Z mode disabled 9.75 mW 1 MSPS, high-Z mode disabled 4.9 mW REF Only 2 MSPS, high-Z mode disabled 3.75 mW 1 MSPS, high-Z mode disabled 1.9 mW VIO Only 2 MSPS, high-Z mode disabled 0.5 mW 1 MSPS, high-Z mode disabled 0.2 mW Energy per Conversion 7 nJ/sample TEMPERATURE RANGE Specified Performance TMIN to TMAX −40 +125 °C 1 The acquisition phase is the time available for the input sampling capacitors to acquire a new input with the ADC running at a throughput rate of 2 MSPS for the AD4000 and of 1 MSPS for the AD4004. 2 A throughput rate of 2 MSPS can only be achieved with turbo mode enabled and a minimum SCK rate of 70 MHz. The minimum SCK rate required for 1 MSPS operation is 25 MHz with turbo mode enabled. Refer to Table 4 for the maximum achievable throughput for different modes of operation. 3 Transient response is the time required for the ADC to acquire a full-scale input step to ±0.5 LSB accuracy. 4 The minimum and maximum values are guaranteed by characterization, but not production tested. 5 See the 1/f noise plot in Figure 18. Rev. A | Page 5 of 34 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION TRANSFER FUNCTIONS APPLICATIONS INFORMATION TYPICAL APPLICATION DIAGRAMS ANALOG INPUTS Input Overvoltage Clamp Circuit Switched Capacitor Input RC Filter Values DRIVER AMPLIFIER CHOICE High Frequency Input Signals EASE OF DRIVE FEATURES Input Span Compression High-Z Mode Long Acquisition Phase VOLTAGE REFERENCE INPUT POWER SUPPLY DIGITAL INTERFACE REGISTER READ/WRITE FUNCTIONALITY STATUS WORD CSB MODE, 3-WIRE TURBO MODE CSB MODE, 3-WIRE WITHOUT BUSY INDICATOR CSB MODE, 3-WIRE WITH BUSY INDICATOR CSB MODE, 4-WIRE TURBO MODE CSB MODE, 4-WIRE WITHOUT BUSY INDICATOR CSB MODE, 4-WIRE WITH BUSY INDICATOR DAISY-CHAIN MODE LAYOUT GUIDELINES EVALUATING THE AD4000/AD4004 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
