Datasheet AD7768, AD7768-4 (Analog Devices) - 8
Description4-Channel, 24-Bit, Simultaneous Sampling ADC, Power Scaling, 110.8 kHz BW
Pages / Page99 / 8 — AD7768/AD7768-4. Data Sheet. Parameter. Test Conditions/Comments. Min. …
RevisionB
AD7768/AD7768-4. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD7768/AD7768-4 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
link to page 58 link to page 70 link to page 16 link to page 6 link to page 6 link to page 6 link to page 12 link to page 6 link to page 12 link to page 6 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12
Sinc5 Filter FILTER = 1 Decimation Rate Up to six selectable decimation rates; see 32 1024 the Decimation Rate Control section Group Delay Latency 3/ODR sec Settling Time Complete settling, see Table 36 7/ODR sec Pass Band −3 dB bandwidth 0.204 × ODR Hz REJECTION AC Power Supply Rejection VIN = 0.1 V, AVDD1 = 5 V, AVDD2 = 5 V, Ratio (PSRR) IOVDD = 2.5 V AVDD1 90 dB AVDD2 100 dB IOVDD 75 dB DC PSRR VIN = 1 V AVDD1 100 dB AVDD2 118 dB IOVDD 90 dB Analog Input Common-Mode Rejection Ratio (CMRR) DC VIN = 0.1 V 95 dB AC Up to 10 kHz 95 dB Crosstalk −0.5 dBFS input on adjacent channels −120 dB CLOCK Crystal Frequency 8 32.768 34 MHz External Clock (MCLK) See the Timing Specifications section 32.768 MHz Duty Cycle For data sheet performance 50:50 % MCLK Pulse Width2 Functionality Logic Low 12.2 ns Logic High 12.2 ns CMOS Clock Input Voltage See the logic inputs parameter High, VINH Low, VINL LVDS Clock2 RL = 100 Ω Differential Input Voltage 100 650 mV Common-Mode Input 800 1575 mV Voltage Absolute Input Voltage 1.88 V ADC RESET2 ADC Start-Up Time After Reset6 Time to first DRDY, fast mode, decimation 1.58 1.66 ms by 32 Minimum RESET Low Pulse tMCLK = 1/MCLK 2 × tMCLK Width LOGIC INPUTS See Table 2 for 1.8 V operation Input Voltage2 High, VINH 0.65 × V IOVDD Low, VINL 0.7 V Hysteresis2 0.04 0.09 V Leakage Current −10 +0.03 +10 µA RESET pin7 −10 +10 µA LOGIC OUTPUTS See Table 2 for 1.8 V operation Output Voltage2 High, VOH ISOURCE = 200 μA 0.8 × IOVDD V Low, VOL ISINK = 400 µA 0.4 V Rev. A | Page 8 of 99 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS 1.8 V IOVDD SPECIFICATIONS TIMING SPECIFICATIONS 1.8 V IOVDD TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CLOCKING, SAMPLING TREE, AND POWER SCALING Example of Power vs. Noise Performance Optimization Configuration A Configuration B Clocking Out the ADC Conversion Results (DCLK) NOISE PERFORMANCE AND RESOLUTION APPLICATIONS INFORMATION POWER SUPPLIES Recommended Power Supply Configuration 1.8 V IOVDD Operation Analog Supply Internal Connectivity DEVICE CONFIGURATION Interface Data Format PIN CONTROL Setting the Filter Setting the Decimation Rate Operating Mode Diagnostics Configuration Example Channel Standby SPI CONTROL Accessing the ADC Register Map SPI Interface Details SPI Control Interface Error Handling SPI Reset Configuration SPI CONTROL FUNCTIONALITY Channel Configuration Channel Modes Reset over SPI Control Interface Sleep Mode Channel Standby Clocking Selections MCLK Source Selection Interface Configuration CRC Protection ADC Synchronization over SPI Analog Input Precharge Buffers Reference Precharge Buffers Per Channel Calibration Gain, Offset, and Sync Phase GPIOs SPI CONTROL MODE EXTRA DIAGNOSTIC FEATURES RAM Built In Self Test Revision Identification Number Diagnostic Meter Mode CIRCUIT INFORMATION CORE SIGNAL CHAIN ADC Power Modes ANALOG INPUTS VCM REFERENCE INPUT CLOCK SELECTION DIGITAL FILTERING Sinc5 Filter Wideband Low Ripple Filter DECIMATION RATE CONTROL ANTIALIASING Modulator Sampling Frequency Modulator Chopping Frequency Modulator Saturation Point CALIBRATION Offset Adjustment Gain Adjustment Sync Phase Offset Adjustment DATA INTERFACE SETTING THE FORMAT OF DATA OUTPUT ADC CONVERSION OUTPUT: HEADER AND DATA Chip Error Filter Not Settled Repeated Data Filter Type Filter Saturated Channel ID Data Interface: Standard Conversion Operation Data Interface: One-Shot Conversion Operation Daisy-Chaining Synchronization CRC Check on Data Interface FUNCTIONALITY GPIO FUNCTIONALITY AD7768 REGISTER MAP DETAILS (SPI CONTROL) AD7768 REGISTER MAP CHANNEL STANDBY REGISTER CHANNEL MODE A REGISTER CHANNEL MODE B REGISTER CHANNEL MODE SELECT REGISTER POWER MODE SELECT REGISTER GENERAL DEVICE CONFIGURATION REGISTER DATA CONTROL: SOFT RESET, SYNC, AND SINGLE-SHOT CONTROL REGISTER INTERFACE CONFIGURATION REGISTER DIGITAL FILTER RAM BUILT IN SELF TEST (BIST) REGISTER STATUS REGISTER REVISION IDENTIFICATION REGISTER GPIO CONTROL REGISTER GPIO WRITE DATA REGISTER GPIO READ DATA REGISTER ANALOG INPUT PRECHARGE BUFFER ENABLE REGISTER CHANNEL 0 TO CHANNEL 3 ANALOG INPUT PRECHARGE BUFFER ENABLE REGISTER CHANNEL 4 TO CHANNEL 7 POSITIVE REFERENCE PRECHARGE BUFFER ENABLE REGISTER NEGATIVE REFERENCE PRECHARGE BUFFER ENABLE REGISTER OFFSET REGISTERS GAIN REGISTERS SYNC PHASE OFFSET REGISTERS ADC DIAGNOSTIC RECEIVE SELECT REGISTER ADC DIAGNOSTIC CONTROL REGISTER MODULATOR DELAY CONTROL REGISTER CHOPPING CONTROL REGISTER AD7768-4 REGISTER MAP DETAILS (SPI CONTROL) AD7768-4 REGISTER MAP CHANNEL STANDBY REGISTER CHANNEL MODE A REGISTER CHANNEL MODE B REGISTER CHANNEL MODE SELECT REGISTER POWER MODE SELECT REGISTER GENERAL DEVICE CONFIGURATION REGISTER DATA CONTROL: SOFT RESET, SYNC, AND SINGLE-SHOT CONTROL REGISTER INTERFACE CONFIGURATION REGISTER DIGITAL FILTER RAM BUILT IN SELF TEST (BIST) REGISTER STATUS REGISTER REVISION IDENTIFICATION REGISTER GPIO CONTROL REGISTER GPIO WRITE DATA REGISTER GPIO READ DATA REGISTER ANALOG INPUT PRECHARGE BUFFER ENABLE REGISTER CHANNEL 0 AND CHANNEL 1 ANALOG INPUT PRECHARGE BUFFER ENABLE REGISTER CHANNEL 2 AND CHANNEL 3 POSITIVE REFERENCE PRECHARGE BUFFER ENABLE REGISTER NEGATIVE REFERENCE PRECHARGE BUFFER ENABLE REGISTER OFFSET REGISTERS GAIN REGISTERS SYNC PHASE OFFSET REGISTERS ADC DIAGNOSTIC RECEIVE SELECT REGISTER ADC DIAGNOSTIC CONTROL REGISTER MODULATOR DELAY CONTROL REGISTER CHOPPING CONTROL REGISTER OUTLINE DIMENSIONS ORDERING GUIDE
