Datasheet AD7761 (Analog Devices) - 4
Description8-Channel, 16-Bit, Simultaneous Sampling ADC with Power Scaling, 110.8 kHz BW
Pages / Page76 / 4 — Data Sheet. AD7761. REVISION HISTORY. 9/2017—Rev. 0 to Rev. A. …
RevisionA
Data Sheet. AD7761. REVISION HISTORY. 9/2017—Rev. 0 to Rev. A. 4/2016—Revision 0: Initial Version
Data Sheet AD7761 REVISION HISTORY 9/2017—Rev 0 to Rev A 4/2016—Revision 0: Initial Version
Data Sheet AD7761 REVISION HISTORY 9/2017—Rev. 0 to Rev. A
Moved Table 26 .. 45 Changed Focus Mode to Low Power Mode ... Throughout Changes to Modulator Saturation Point Section .. 47 Changes to Table 1 .. 5 Added Figure 68 .. 47 Changes to Figure 2 ... 13 Changes to Bit 7 Bit Name, Table 31, and ERROR_FLAGGED Changes to Thermal Resistance Section and Table 7 ... 15 Section .. 50 Changes to Table 8 .. 16 Changes to Data Interface: One-Shot Conversion Operation Changes to Figure 47 .. 27 Section .. 53 Changes to Figure 48 .. 30 Changes to CRC Check on Data Interface Section .. 55 Changes to MCLK Source Selection Section ... 37 Added CRC Code Example Section ... 56 Changes to Analog Input Precharge Buffers Section ... 38 Change to Register 0x05, Bit 6, Table 33 .. 60 Changes to Analog Inputs Section .. 40 Changes to Table 39 .. 65 Added Figure 61; Renumbered Sequentially ... 41 Changes to Analog Input Precharge Buffer Enable Register Changes to Table 24 .. 41 Channel 0 to Channel 3 Section .. 69 Changes to Reference Input Section ... 42 Changes to Analog Input Precharge Buffer Enable Register Added Figure 62 .. 42 Channel 4 to Channel 7 Section .. 70 Added Filter Settling Time Section ... 43 Changes to Wideband Low Ripple Filter Section ... 43
Moved Table 25 .. 44 Rev. A | Page 3 of 75 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS TIMING SPECIFICATIONS 1.8 V IOVDD TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CLOCKING, SAMPLING TREE, AND POWER SCALING Example of Power vs. Noise Performance Optimization Configuration A Configuration B Clocking Out the ADC Conversion Results (DCLK) NOISE PERFORMANCE AND RESOLUTION APPLICATIONS INFORMATION POWER SUPPLIES Recommended Power Supply Configuration 1.8 V IOVDD Operation Analog Supply Internal Connectivity DEVICE CONFIGURATION Interface Data Format PIN CONTROL MODE Setting the Filter Setting the Decimation Rate Operating Mode Diagnostics Configuration Example Channel Standby SPI CONTROL Accessing the ADC Register Map SPI Interface Details SPI Control Interface Error Handling SPI Reset Configuration SPI CONTROL FUNCTIONALITY Channel Configuration Channel Modes Reset over SPI Control Interface Sleep Mode Channel Standby Mode Clocking Selections MCLK Source Selection Interface Configuration CRC Protection ADC Synchronization over SPI Analog Input Precharge Buffers Reference Precharge Buffers Per Channel Calibration Gain, Offset, and Sync Phase GPIOs SPI CONTROL MODE EXTRA DIAGNOSTIC FEATURES RAM Built In Self Test Revision Identification Number Diagnostic Meter Mode CIRCUIT INFORMATION CORE SIGNAL CHAIN ADC Power Modes ANALOG INPUTS VCM REFERENCE INPUT CLOCK SELECTION DIGITAL FILTERING Sinc5 Filter Wideband Low Ripple Filter Filter Settling Time DECIMATION RATE CONTROL ANTIALIASING Modulator Sampling Frequency Modulator Chopping Frequency Modulator Saturation Point CALIBRATION Offset Adjustment Gain Adjustment Sync Phase Offset Adjustment DATA INTERFACE SETTING THE FORMAT OF DATA OUTPUT ADC CONVERSION OUTPUT: HEADER AND DATA ERROR_FLAGGED Filter Not Settled Repeated Data Filter Type Filter Saturated Channel ID Data Interface: Standard Conversion Operation Data Interface: One-Shot Conversion Operation Daisy-Chaining Synchronization CRC Check on Data Interface CRC Code Example FUNCTIONALITY GPIO FUNCTIONALITY REGISTER MAP DETAILS (SPI CONTROL) REGISTER MAP CHANNEL STANDBY REGISTER CHANNEL MODE A REGISTER CHANNEL MODE B REGISTER CHANNEL MODE SELECT REGISTER POWER MODE SELECT REGISTER GENERAL DEVICE CONFIGURATION REGISTER DATA CONTROL: SOFT RESET, SYNC, AND SINGLE-SHOT CONTROL REGISTER INTERFACE CONFIGURATION REGISTER DIGITAL FILTER RAM BUILT IN SELF TEST (BIST) REGISTER STATUS REGISTER REVISION IDENTIFICATION REGISTER GPIO CONTROL REGISTER GPIO WRITE DATA REGISTER GPIO READ DATA REGISTER ANALOG INPUT PRECHARGE BUFFER ENABLE REGISTER CHANNEL 0 TO CHANNEL 3 ANALOG INPUT PRECHARGE BUFFER ENABLE REGISTER CHANNEL 4 TO CHANNEL 7 POSITIVE REFERENCE PRECHARGE BUFFER ENABLE REGISTER NEGATIVE REFERENCE PRECHARGE BUFFER ENABLE REGISTER OFFSET REGISTERS GAIN REGISTERS SYNC PHASE OFFSET REGISTERS ADC DIAGNOSTIC RECEIVE SELECT REGISTER ADC DIAGNOSTIC CONTROL REGISTER MODULATOR DELAY CONTROL REGISTER CHOPPING CONTROL REGISTER OUTLINE DIMENSIONS ORDERING GUIDE
