Datasheet AD7915, AD7916 (Analog Devices) - 6
Description16-Bit, 1 MSPS/500 kSPS PulSAR ADCs in MSOP/LFCSP
Pages / Page26 / 6 — AD7915/AD7916. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter …
File Format / SizePDF / 567 Kb
AD7915/AD7916. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter Rating. ESD CAUTION
AD7915/AD7916 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
link to page 15
AD7915/AD7916 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Analog Inputs stress rating only; functional operation of the product at these IN+, IN− to GND1 −0.3 V to V or any other conditions above those indicated in the operational REF + 0.3 V or ±130 mA Supply Voltage section of this specification is not implied. Operation beyond REF, VIO to GND −0.3 V to +6.0 V the maximum operating conditions for extended periods may VDD to GND −0.3 V to +3.0 V affect product reliability. VDD to VIO −6 V to +3 V Digital Inputs to GND −0.3 V to VIO + 0.3 V
ESD CAUTION
Digital Output to GND −0.3 V to VIO + 0.3 V Storage Temperature −65°C to +150°C Range Junction Temperature 150°C θJA Thermal Impedance 10-Lead MSOP 200°C/W 10-Lead LFCSP_WD 48.7°C/W θ JC Thermal Impedance 10-Lead MSOP 44°C/W 10-Lead LFCSP_WD 2.96°C/W Reflow Soldering JEDEC Standard (J-STD-020) 1 See the Analog Inputs section for an explanation of IN+ and IN−. Rev. 0 | Page 6 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATIONS CIRCUIT TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM ANALOG INPUTS DRIVER AMPLIFIER CHOICE SINGLE TO DIFFERENTIAL DRIVER VOLTAGE REFERENCE INPUT POWER SUPPLY DIGITAL INTERFACE MODE, 3-WIRE, WITHOUT BUSY INDICATOR MODE 3-WIRE, WITH BUSY INDICATOR MODE, 4-WIRE, WITHOUT BUSY INDICATOR MODE 4-WIRE WITH BUSY INDICATOR CHAIN MODE, WITHOUT BUSY INDICATOR CHAIN MODE WITH BUSY INDICATOR APPLICATIONS INFORMATION INTERFACING TO BLACKFIN DSP LAYOUT EVALUATING AD7915/AD7916 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE NOTES
