Datasheet AD7902 (Analog Devices) - 2
DescriptionDual Pseudo Differential 16-Bit, 1 MSPS PulSAR ADC 12.0 mW in QSOP
Pages / Page29 / 2 — AD7902* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 691 Kb
AD7902* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Press. EVALUATION KITS
AD7902* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Press EVALUATION KITS
View a parametric search of comparable parts.
Press
• Analog Devices Releases Two Dual A/D Converters with
EVALUATION KITS
Lowest Power/Highest Linearity Combination Available • AD7902 Evaluation Board • Most Power Efficient Drivers For 12-, 14- And 16-bit A/D Converters Unveiled
DOCUMENTATION Product Selection Guide Application Notes
• SAR ADC & Driver Quick-Match Guide • AN-742: Frequency Domain Response of Switched-
Technical Articles
Capacitor ADCs • MS-1779: Nine Often Overlooked ADC Specifications • AN-877: Interfacing to High Speed ADCs via SPI • MS-2022: Seven Steps to Successful Analog-to-Digital • AN-931: Understanding PulSAR ADC Support Circuitry Signal Conversion (Noise Calculation for Proper Signal Conditioning) • AN-935: Designing an ADC Transformer-Coupled Front End • MS-2124: Understanding AC Behaviors of High Speed ADCs
Data Sheet
• MS-2210: Designing Power Supplies for High Speed ADC • AD7902: Dual Pseudo Differential 16-Bit, 1 MSPS PulSAR ADC 12.0 mW in QSOP Data Sheet
Tutorials Product Highlight
• MT-002: What the Nyquist Criterion Means to Your Sampled Data System Design • [NO TITLE FOUND] Product Highlight • MT-031: Grounding Data Converters and Solving the • Lowest-Power 16-Bit ADC Optimizes Portable Designs Mystery of "AGND" and "DGND" (eeProductCenter, 10/4/2006)
User Guides DESIGN RESOURCES
• UG-608: Evaluating the AD7902 Dual Pseudo Differential, • AD7902 Material Declaration 16-Bit, 1 MSPS PulSAR ADC • PCN-PDN Information
TOOLS AND SIMULATIONS
• Quality And Reliability • AD7902 IBIS Model • Symbols and Footprints
DISCUSSIONS
View all AD7902 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM ANALOG INPUTS DRIVER AMPLIFIER CHOICE VOLTAGE REFERENCE INPUT POWER SUPPLY DIGITAL INTERFACE CS MODE /CS Mode, 3-Wire Interface Without Busy Indicator /CS Mode, 3-Wire Interface with Busy Indicator /CS Mode, 4-Wire Interface Without Busy Indicator /CS Mode, 4-Wire Interface with Busy Indicator CHAIN MODE Chain Mode Without Busy Indicator Chain Mode with Busy Indicator APPLICATIONS INFORMATION SIMULTANEOUS SAMPLING FUNCTIONAL SAFTEY CONSIDERATIONS LAYOUT EVALUATING PERFORMANCE OF THE AD7902 OUTLINE DIMENSIONS ORDERING GUIDE NOTES
