Datasheet AD7960 (Analog Devices) - 8
Description18-Bit, 5 MSPS PULSAR® Differential ADC
Pages / Page25 / 8 — Data Sheet. AD7960. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. …
RevisionC
File Format / SizePDF / 813 Kb
Data Sheet. AD7960. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. Parameter. Rating. Table 5. Thermal Resistance
Data Sheet AD7960 ABSOLUTE MAXIMUM RATINGS Table 4 THERMAL RESISTANCE Parameter Rating Table 5 Thermal Resistance
link to page 8
Data Sheet AD7960 ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE Parameter Rating
θJA is specified for the worst-case conditions, that is, a device Analog Inputs/Outputs soldered in a circuit board for surface-mount packages. IN+, IN− to GND −0.3 V to VDD1 REF1 to GND −0.3 V to +6 V
VCM to GND −0.3 V to +6 V
Package Type θJA θJC Unit
REFIN to GND −0.3 V to +6 V 32-Lead LFCSP_VQ 40 4 °C/W Supply Voltages VDD1 −0.3 V to +6 V
ESD CAUTION
VDD2, VIO −0.3 V to +2.1 V Digital Inputs to GND −0.3 V to VIO + 0.3 V Digital Outputs to GND −0.3 V to VIO + 0.3 V Input Current to Any Pin ±10 mA Except Supplies Operating Temperature −40°C to +85°C Range (Commercial) Storage Temperature Range −65°C to +150°C Junction Temperature 150°C ESD Ratings Human Body Model 4 kV Machine Model 200 V Field-Induced Charged- 1.25 kV Device Model 1 Transient currents of up to 100 mA do not cause SCR latch-up. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. C | Page 7 of 24 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Information Transfer Function Analog Inputs Typical Applications Voltage Reference Options Wake-Up Time from Power-Down and Snooze Modes Power Supply Power-Up Digital Interface Conversion Control Echoed Clock Interface Mode Self Clocked Mode Applications Information Layout Evaluating AD7960 Performance Outline Dimensions Ordering Guide
