Datasheet AD9645 (Analog Devices) - 2
DescriptionDual, 14-Bit, 80 MSPS/125 MSPS Serial LVDS 1.8 V Analog-to-Digital Converter
Pages / Page37 / 2 — AD9645* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionB
AD9645* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9645* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9645 IBIS Model
EVALUATION KITS
• AD9645 S-Parameter • AD9645 Evaluation Board
REFERENCE MATERIALS DOCUMENTATION Press Application Notes
• Analog Devices’ Dual 14-bit A/D Converter Reduces • AN-1142: Techniques for High Speed ADC PCB Layout Power and Size in Communications, Instrumentation, Test and Measurement Applications • AN-501: Aperture Uncertainty and ADC System Performance
Technical Articles
• AN-737: How ADIsimADC Models an ADC • MS-2210: Designing Power Supplies for High Speed ADC • AN-742: Frequency Domain Response of Switched- Capacitor ADCs
DESIGN RESOURCES
• AN-756: Sampled Systems and the Effects of Clock Phase • AD9645 Material Declaration Noise and Jitter • PCN-PDN Information • AN-807: Multicarrier WCDMA Feasibility • Quality And Reliability • AN-808: Multicarrier CDMA2000 Feasibility • Symbols and Footprints • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs
DISCUSSIONS
• AN-835: Understanding High Speed ADC Testing and View all AD9645 EngineerZone Discussions. Evaluation • AN-878: High Speed ADC SPI Control Software
SAMPLE AND BUY
• AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual Visit the product page to see pricing options. • AN-935: Designing an ADC Transformer-Coupled Front End
TECHNICAL SUPPORT Data Sheet
Submit a technical question or find your regional support number. • AD9645: Dual, 14-Bit, 80 MSPS/125 MSPS, Serial LVDS 1.8 V Analog-to-Digital Converter
DOCUMENT FEEDBACK User Guides
• AD9655/AD9645/AD9635 Evaluation Documentation Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS AD9645-80 AD9645-125 EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS AND TIMING SDIO/PDWN Pin SCLK/DFS Pin CSB Pin RBIAS Pin OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Channel-Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Device Index (Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Bits[7:2]—Open Bits[1:0]—Power Mode Enhancement Control (Register 0x0C) Bits[7:3]—Open Bit 2—Chop Mode Bits[1:0]—Open Output Mode (Register 0x14) Bit 7—Open Bit 6—LVDS-ANSI/LVDS-IEEE Option Bits[5:3]—Open Bit 2—Output Invert Bit 1—Open Bit 0—Output Format Output Adjust (Register 0x15) Bits[7:6]—Open Bits[5:4]—Output Driver Termination Bits[3:1]—Open Bit 0—Output Drive Output Phase (Register 0x16) Bit 7—Open Bits[6:4]—Input Clock Phase Adjust Bits[3:0]—Output Clock Phase Adjust Serial Output Data Control (Register 0x21) Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) Bits[7:1]—Open Bit 0—SDIO Pull-Down User I/O Control 3 (Register 0x102) Bits[7:4]—Open Bit 3—VCM Power-Down Bits[2:0]—Open APPLICATIONS INFORMATION DESIGN GUIDELINES POWER AND GROUND GUIDELINES CLOCK STABILITY CONSIDERATIONS EXPOSED PAD THERMAL HEAT SLUG RECOMMENDATIONS VCM REFERENCE DECOUPLING SPI PORT OUTLINE DIMENSIONS ORDERING GUIDE
