Datasheet AD9633 (Analog Devices)
Description | Quad, 12-Bit, 80/105/125 MSPS Serial LVDS 1.8 V A/D Converter |
Pages / Page | 42 / 1 — Quad, 12-Bit, 80 MSPS/105 MSPS/. 125 MSPS, Serial LVDS 1.8 V ADC. Data … |
Revision | C |
File Format / Size | PDF / 1.2 Mb |
Quad, 12-Bit, 80 MSPS/105 MSPS/. 125 MSPS, Serial LVDS 1.8 V ADC. Data Sheet. AD9633. FEATURES. FUNCTIONAL BLOCK DIAGRAM. AVDD. PDWN
Quad, 12-Bit, 80 MSPS/105 MSPS/ 125 MSPS, Serial LVDS 1.8 V ADC Data Sheet AD9633 FEATURES FUNCTIONAL BLOCK DIAGRAM AVDD PDWN DRVDD 1.8 V supply operation Low power: 100 mW per channel at 125 MSPS with scalable 12 SERIAL D0+A VIN+A PIPELINE DIGITAL LVDS D0–A power options VIN–A ADC SERIALIZER SERIAL D1+A SNR = 71 dB (to Nyquist) 12 LVDS D1–A VIN+B SFDR = 91 dBc (to Nyquist) PIPELINE DIGITAL SERIAL D0+B VIN–B ADC SERIALIZER LVDS D0–B DNL = ±0.3 LSB (typical); INL = ±0.5 LSB (typical) RBIAS SERIAL D1+B VREF Serial LVDS (ANSI-644, default) and low power, reduced LVDS D1–B SENSE FCO+ signal option (similar to IEEE 1596.3) REF 1V AD9633 FCO– SELECT 650 MHz full power analog bandwidth AGND SERIAL D0+C 12 LVDS D0–C 2 V p-p input voltage range VIN+C PIPELINE DIGITAL D1+C SERIAL Serial port control VIN–C ADC SERIALIZER LVDS D1–C Full chip and individual channel power-down modes 12 SERIAL D0+D VIN+D PIPELINE DIGITAL LVDS D0–D Flexible bit orientation VIN–D ADC SERIALIZER SERIAL D1+D Built-in and custom digital test pattern generation LVDS D1–D SERIAL PORT CLOCK DCO+ Multichip sync and clock divider VCM INTERFACE MANAGEMENT DCO– Programmable output clock and data alignment Programmable output resolution B M C + – TP N K CS /D
1
Standby mode SY CLK CL IO/OL LK
00
D
3-
C S S
07 10
Figure 1.
Medical ultrasound High speed imaging Quadrature radio receivers Diversity radio receivers
The ADC contains several features designed to maximize
Test equipment
flexibility and minimize system cost, such as programmable
GENERAL DESCRIPTION
output clock and data alignment and digital test pattern generation. The available digital test patterns include built-in The AD9633 is a quad, 12-bit, 80 MSPS/105 MSPS/125 MSPS deterministic and pseudorandom patterns, along with custom user- analog-to-digital converter (ADC) with an on-chip sample-and- defined test patterns entered via the serial port interface (SPI). hold circuit designed for low cost, low power, small size, and The AD9633 is available in a RoHS-compliant, 48-lead LFCSP. ease of use. The product operates at a conversion rate of up to It is specified over the industrial temperature range of −40°C to 125 MSPS and is optimized for outstanding dynamic performance +85°C. This product is protected by a U.S. patent. and low power in applications where a small package size is critical.
PRODUCT HIGHLIGHTS
The ADC requires a single 1.8 V power supply and LVPECL-/ 1. Small Footprint. Four ADCs are contained in a small, space- CMOS-/LVDS-compatible sample rate clock for full performance saving package. operation. No external reference or driver components are 2. Low power of 100 mW/channel at 125 MSPS with scalable required for many applications. power options. The ADC automatically multiplies the sample rate clock for the 3. Pin compatible to the AD9253 14-bit quad ADC. appropriate LVDS serial data rate. A data clock output (DCO) for 4. Ease of Use. A data clock output (DCO) operates at capturing data on the output and a frame clock output (FCO) frequencies of up to 375 MHz and supports double data for signaling a new output byte are provided. Individual-channel rate (DDR) operation. 5. User Flexibility. The SPI control offers a wide range of flexible power-down is supported and typically consumes less than 2 mW features to meet specific system requirements. when all channels are disabled.
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2011–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics AD9633-80 AD9633-105 AD9633-125 Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/OLM Pin SCLK/DTP Pin CSB Pin RBIAS Pin Output Test Modes Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Channel-Specific Registers Memory Map Register Table Memory Map Register Descriptions Device Index (Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Bits[7:6]—Open Bit 5—External Power-Down Pin Function Bits[4:2]—Open Bits[1:0]—Power Mode Enhancement Control (Register 0x0C) Bits[7:3]—Open Bit 2—Chop Mode Bits[1:0]—Open Output Mode (Register 0x14) Bit 7—Open Bit 6—LVDS-ANSI/LVDS-IEEE Option Bits[5:3]—Open Bit 2—Output Invert Bit 1—Open Bit 0—Output Format Output Adjust (Register 0x15) Bits[7:6]—Open Bits[5:4]—Output Driver Termination Bits[3:1]—Open Bit 0—Output Drive Output Phase (Register 0x16) Bit 7—Open Bits[6:4]—Input Clock Phase Adjust Bits[3:0]—Output Clock Phase Adjust Serial Output Data Control (Register 0x21) Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) Bits[7:1]—Open Bit 0—SDIO Pull-Down User I/O Control 3 (Register 0x102) Bits[7:4]—Open Bit 3—VCM Power-Down Bits[2:0]—Open Applications Information Design Guidelines Power and Ground Recommendations Clock Stability Considerations Exposed Pad Thermal Heat Slug Recommendations VCM Reference Decoupling SPI Port Crosstalk Performance Outline Dimensions Ordering Guide
