Datasheet AD9608 (Analog Devices) - 9
Description10-Bit, 125/105 MSPS, 1.8 V Dual Analog-to-Digital Converter
Pages / Page41 / 9 — AD9608. Data Sheet. TIMING SPECIFICATIONS. Table 5. Parameter. …
RevisionC
AD9608. Data Sheet. TIMING SPECIFICATIONS. Table 5. Parameter. Descriptions. Limit. Timing Diagrams. N – 1. N + 4. N + 5. N + 3. VIN. N + 1. N + 2
AD9608 Data Sheet TIMING SPECIFICATIONS Table 5 Parameter Descriptions Limit Timing Diagrams N – 1 N + 4 N + 5 N + 3 VIN N + 1 N + 2
AD9608 Data Sheet TIMING SPECIFICATIONS Table 5. Parameter Descriptions Limit
SYNC TIMING REQUIREMENTS tSSYNC SYNC to rising edge of CLK+ setup time 0.24 ns typ tHSYNC SYNC to rising edge of CLK+ hold time 0.40 ns typ SPI TIMING REQUIREMENTS tDS Setup time between the data and the rising edge of SCLK 2 ns min tDH Hold time between the data and the rising edge of SCLK 40 ns min tCLK Period of the SCLK 2 ns min tS Setup time between CSB and SCLK 2 ns min tH Hold time between CSB and SCLK 10 ns min tHIGH SCLK pulse width high 10 ns min tLOW SCLK pulse width low 10 ns min tEN_SDIO Time required for the SDIO pin to switch from an input to an output relative to the 10 ns min SCLK falling edge tDIS_SDIO Time required for the SDIO pin to switch from an output to an input relative to the 2 ns min SCLK rising edge
Timing Diagrams N – 1 N + 4 tA N + 5 N N + 3 VIN N + 1 N + 2 tCH tCLK CLK+ CLK– tDCO DCOA/DCOB tSKEW CH A/CH B DATA N – 17 N – 16 N – 15 N – 14 N – 13 N – 12
-002
tPD
09977 Figure 2. CMOS Default Output Mode Data Output Timing
N – 1 N + 4 tA N + 5 N N + 3 VIN N + 1 N + 2 tCH tCLK CLK+ CLK– tDCO DCOA/DCOB tSKEW CH A CH B CH A CH B CH A CH B CH A CH B CH A CH A DATA N – 16 N – 16 N – 15 N – 15 N – 14 N – 14 N – 13 N – 13 N – 12 tPD
-003
CH B CH A CH B CH A CH B CH A CH B CH A CH B CH B DATA N – 16 N – 16 N – 15 N – 15 N – 14 N – 14 N – 13 N – 13 N – 12
977 09 Figure 3. CMOS Interleaved Output Mode Data Output Timing Rev. C | Page 8 of 40 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS AD9608-125 AD9608-105 EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations CHANNEL/CHIP SYNCHRONIZATION POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) TIMING Data Clock Output (DCO) OUTPUT TEST OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Channel-Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Power Modes (Register 0x08) Bits[7:6]—Open Bits[4:2]—Open Bits[1:0]—Internal Power-Down Mode Enhancement Control (Register 0x0C) Bits[7:3]—Open Bit 2—Chop Mode Bits[1:0]—Open Output Mode (Register 0x14) Bits[7:6]—Output Port Logic Type Bit 5—Output Interleave Enable Bit 4—Output Port Disable Bit 3—Open Bit 2—Output Invert Bits[1:0]—Output Format Sync Control (Register 0x3A) Bits[7:3]—Open Bit 2—Clock Divider Next Sync Only Bit 1—Clock Divider Sync Enable Bit 0—Open Transfer (Register 0xFF) Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) Bit 7—OEB Pin Enable Bits[6:1]—Open Bit 0—SDIO Pull-Down User I/O Control 3 (Register 0x102) Bits[7:4]—Open Bit 3—VCM Power-Down Bits[2:0]—Open APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations LVDS Operation Clock Stability Considerations Exposed Paddle Thermal Heat Slug Recommendations VCM Reference Decoupling SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
