Datasheet AD9643 (Analog Devices) - 9
Description14-Bit, 170 MSPS/210 MSPS/250 MSPS, 1.8 V Dual Analog-to-Digital Converter (ADC)
Pages / Page36 / 9 — Data Sheet. AD9643. TIMING SPECIFICATIONS. Table 5. Parameter. …
RevisionF
Data Sheet. AD9643. TIMING SPECIFICATIONS. Table 5. Parameter. Conditions. Min. Typ. Max. Unit
Data Sheet AD9643 TIMING SPECIFICATIONS Table 5 Parameter Conditions Min Typ Max Unit
Data Sheet AD9643 TIMING SPECIFICATIONS Table 5. Parameter Conditions Min Typ Max Unit
SYNC TIMING REQUIREMENTS tSSYNC SYNC to the rising edge of CLK setup time 1 0.3 ns tHSYNC SYNC to the rising edge of CLK hold time 1 0.4 ns SPI TIMING REQUIREMENTS tDS Setup time between the data and the rising edge of SCLK 2 ns tDH Hold time between the data and the rising edge of SCLK 2 ns tCLK Period of the SCLK 40 ns tS Setup time between CSB and SCLK 2 ns tH Hold time between CSB and SCLK 2 ns tHIGH Minimum period that SCLK should be in a logic high state 10 ns tLOW Minimum period that SCLK should be in a logic low state 10 ns tEN_SDIO Time required for the SDIO pin to switch from an input to an output 10 ns relative to the SCLK falling edge tDIS_SDIO Time required for the SDIO pin to switch from an output to an input 10 ns relative to the SCLK rising edge Rev. E | Page 9 of 36 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications ADC DC Specifications ADC AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation ADC Architecture Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Clock Input Considerations Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations Power Dissipation and Standby Mode Digital Outputs Digital Output Enable Function (OEB) Timing Data Clock Output (DCO) ADC Overrange (OR) Channel/Chip Synchronization Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface SPI Accessible Features Memory Map Reading the Memory Map Register Table Open and Reserved Locations Default Values Logic Levels Transfer Register Map Channel-Specific Registers Memory Map Register Table Memory Map Register Description Sync Control (Register 0x3A) Bits[7:3]—Reserved Bit 2—Clock Divider Next Sync Only Bit 1—Clock Divider Sync Enable Bit 0—Master Sync Buffer Enable Applications Information Design Guidelines Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations VCM SPI Port Outline Dimensions Ordering Guide
