Datasheet HMCAD1520 (Analog Devices) - 9
DescriptionHigh Speed Multi-Mode 8/12/14-Bit 1000/640/105 MSPS A/D Converter
Pages / Page37 / 9 — HMCAD1520. HigH Speed Multi-Mode 8/12/14-Bit. 1000/640/105 MSpS A/d …
HMCAD1520. HigH Speed Multi-Mode 8/12/14-Bit. 1000/640/105 MSpS A/d Converter. table 3: pin descriptions. Pin name. Description
HMCAD1520 HigH Speed Multi-Mode 8/12/14-Bit 1000/640/105 MSpS A/d Converter table 3: pin descriptions Pin name Description
HMCAD1520
v04.1015
0 t M s s - r Figure 1: Pin Diagram e t r
e v
Pin name Description Pin Number # of Pins
n AvDD Analog power supply, 1.8v 1, 36 2 Csn Chip select enable. Active low 2 1 o sDAtA serial data input 3 1 sCLK serial clock input 4 1 resetn reset sPI interface. Active low 5 1 Power-down input. Activate after applying power in order to A / D C PD initialize the ADC correctly. Alternatively use the sPI power 6 1 down feature DvDD Digital and I/o power supply, 1.8v 7, 30 2 Dvss Digital ground 8, 29 2 DP1A LvDs channel 1A, positive output 9 1 Dn1A LvDs channel 1A, negative output 10 1 DP1B LvDs channel 1B, positive output 11 1 Dn1B LvDs channel 1B, negative output 12 1 DP2A LvDs channel 2A, positive output 13 1 Dn2A LvDs channel 2A, negative output 14 1 DP2B LvDs channel 2B, positive output 15 1 Dn2B LvDs channel 2B, negative output 16 1 Informatio For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, n furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other MA 02062-9106One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com
0 - 8
Phone: 781-329-4700 • Order online at www.analog.com Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Application Support: Phone: 1-800-ANALOG-D
