Datasheet AD7606, AD7606-6, AD7606-4 (Analog Devices) - 6
Description6-Channel DAS with 16-Bit, Bipolar, Simultaneous Sampling ADC
Pages / Page36 / 6 — AD7606/AD7606-6/AD7606-4. Data Sheet. Parameter. Test …
RevisionE
File Format / SizePDF / 938 Kb
AD7606/AD7606-6/AD7606-4. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD7606/AD7606-6/AD7606-4 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
link to page 21 link to page 22 link to page 6
Power Dissipation Normal Mode (Static) AD7606 80 115.5 mW Normal Mode (Operational)8 fSAMPLE = 200 kSPS AD7606 100 142 mW AD7606-6 90 126 mW AD7606-4 75 111 mW Standby Mode 25 42 mW Shutdown Mode 10 31.5 µW 1 Temperature range for the B version is −40°C to +85°C. The AD7606 is operational up to 125°C with throughput rates ≤ 160 kSPS, and the SNR typically reduces by 0.7 dB at 125°C. 2 See the Terminology section. 3 This specification applies when reading during a conversion or after a conversion. If reading during a conversion in paral el mode with VDRIVE = 5 V, SNR typically reduces by 1.5 dB and THD by 3 dB. 4 LSB means least significant bit. With ±5 V input range, 1 LSB = 152.58 µV. With ±10 V input range, 1 LSB = 305.175 µV. 5 These specifications include the full temperature range variation and contribution from the internal reference buffer but do not include the error contribution from the external reference. 6 Bipolar zero code error is calculated with respect to the analog input voltage. See the Analog Input Clamp Protection section. 7 Sample tested during initial release to ensure compliance. 8 Operational power/current figure includes contribution when running in oversampling mode. Rev. C | Page 6 of 36 Document Outline Features Applications Functional Block Diagram Revision History General Description Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Converter Details Analog Input Analog Input Ranges Analog Input Impedance Analog Input Clamp Protection Analog Input Antialiasing Filter Track-and-Hold Amplifiers ADC Transfer Function Internal/External Reference Typical Connection Diagram Power-Down Modes Conversion Control Simultaneous Sampling on All Analog Input Channels Simultaneously Sampling Two Sets of Channels Digital Interface Parallel Interface (PAR/SER/BYTE SEL = 0) Parallel Byte (PAR/SER/BYTE SEL = 1, DB15 = 1) Serial Interface (PAR/SER/BYTE SEL = 1) Reading During Conversion Digital Filter Layout Guidelines Outline Dimensions Ordering Guide
