Datasheet AD9261 (Analog Devices)
Description | 16-Bit, 10 MHz Bandwidth, 30 MSPS to 160 MSPS Continuous Time Sigma-Delta ADC |
Pages / Page | 29 / 1 — 16-Bit, 10 MHz Bandwidth, 30 MSPS to. 160 MSPS Continuous Time … |
File Format / Size | PDF / 624 Kb |
16-Bit, 10 MHz Bandwidth, 30 MSPS to. 160 MSPS Continuous Time Sigma-Delta ADC. AD9261. FEATURES. FUNCTIONAL BLOCK DIAGRAM
16-Bit, 10 MHz Bandwidth, 30 MSPS to 160 MSPS Continuous Time Sigma-Delta ADC AD9261 FEATURES FUNCTIONAL BLOCK DIAGRAM SNR: 83 dB (85 dBFS) to 10 MHz input AVDD DRVDD SFDR: 87 dBc to 10 MHz input OR Noise figure: 15 dB VIN+ Σ-Δ LOW-PASS SAMPLE D15 CMOS DECIMATION RATE Input impedance: 1 kΩ MODULATOR BUFFER VIN– FILTER CONVERTER D0 Power: 340 mW PLL_ 1.8 V analog supply operation LOCKED 1.8 V to 3.3 V output supply PHASE CLK+ VREF LOCKED AD9261 Selectable bandwidth LOOP CLK– 2.5 MHz/5 MHz/10 MHz SERIAL DCO Output data rate: 30 MSPS to 160 MSPS CFILT INTERFACE
1
Integrated decimation filters
00 3- 80
Integrated sample rate converter AGND SDIO SCLK CSB DGND
07 Figure 1.
On-chip PLL clock multiplier On-chip voltage reference Offset binary, Gray code, or twos complement data format Serial control interface (SPI) APPLICATIONS Data acquisition Automated test equipment Instrumentation Medical imaging GENERAL DESCRIPTION
The AD9261 is a single 16-bit analog-to-digital converter The digital output data is presented in offset binary, Gray code, (ADC) based on a continuous time (CT) sigma-delta (Σ-Δ) or twos complement format. A data clock output (DCO) is architecture that achieves 87 dBc of dynamic range over a 10 MHz provided to ensure proper timing with the receiving logic. input bandwidth. The integrated features and characteristics The AD9261 operates on a 1.8 V analog supply and a 1.8 V unique to the continuous time Σ-Δ architecture significantly to 3.3 V digital supply, consuming 340 mW. The AD9261 is simplify its use and minimize the need for external components. available in a 48-lead LFCSP and is specified over the industrial The AD9261 has a resistive input impedance that relaxes the temperature range (−40°C to +85°C). requirements of the driver amplifier. In addition, a 32× oversam-
PRODUCT HIGHLIGHTS
pled fifth-order continuous time loop filter significantly attenuates 1. Continuous time Σ-Δ architecture efficiently achieves high out-of-band signals and aliases, reducing the need for external filters at the input. dynamic range and wide bandwidth. 2. Passive input structure reduces or eliminates the require- An external clock input or the integrated integer-N PLL provides ments for a driver amplifier. the 640 MHz internal clock needed for the oversampled conti- 3. An oversampling ratio of 32× and high order loop filter nuous time Σ-Δ modulator. On-chip decimation filters and sample provide excellent alias rejection reducing or eliminating the rate converters reduce the modulator data rate from 640 MSPS to a need for antialiasing filters. user-defined output data rate from 30 MSPS to 160 MSPS, 4. An integrated decimation filter, sample rate converter, PLL enabling a more efficient and direct interface. clock multiplier, and voltage reference provide ease of use. 5. This part operates from a single 1.8 V analog power supply and 1.8 V to 3.3 V output supply.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2010 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Decimation Filtering Characteristics Digital Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Direct Clocking Internal PLL Clock Distribution External PLL Control PLL Autoband Select Jitter Considerations Power Dissipation and Standby Mode Digital Engine Bandwidth Selection Decimation Filters Sample Rate Converter Cascaded Filter Responses Digital Outputs Digital Output Format Overrange (OR) Condition Timing Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Memory Map Memory Map Definitions Outline Dimensions Ordering Guide
