Datasheet AD7944 (Analog Devices) - 2
Description14-Bit, 2.5 MSPS, PulSAR 15.5 mW ADC in LFCSP
Pages / Page29 / 2 — AD7944* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionC
File Format / SizePDF / 699 Kb
AD7944* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7944* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7944 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7944 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS User Guides
View all AD7944 EngineerZone Discussions. • UG-727: Evaluating the AD7944/AD7985/AD7986 14-/16-/ 18-Bit, PulSAR ADCs
SAMPLE AND BUY
Visit the product page to see pricing options.
REFERENCE MATERIALS Technical Articles TECHNICAL SUPPORT
• MS-2210: Designing Power Supplies for High Speed ADC Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION APPLICATION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION CONVERSION MODES OF OPERATION Transfer Functions TYPICAL APPLICATION DIAGRAM ANALOG INPUTS DRIVER AMPLIFIER CHOICE VOLTAGE REFERENCE INPUT Internal Reference, REF = 4.096 V (PDREF Low) External 1.2 V Reference and Internal Buffer (PDREF High) External Reference (PDREF High, REFIN Low) Reference Decoupling POWER SUPPLY DIGITAL INTERFACE DATA READING OPTIONS Reading During Conversion, Fast Host (Turbo or Normal Mode) Split Reading, Any Speed Host (Turbo or Normal Mode) Reading During Acquisition, Any Speed Host (Turbo or Normal Mode) CS\ MODE, 3-WIRE WITHOUT BUSY INDICATOR CS\ MODE, 3-WIRE WITH BUSY INDICATOR CS\ MODE, 4-WIRE WITHOUT BUSY INDICATOR CS\ MODE, 4-WIRE WITH BUSY INDICATOR CHAIN MODE WITHOUT BUSY INDICATOR CHAIN MODE WITH BUSY INDICATOR APPLICATIONS INFORMATION LAYOUT EVALUATING AD7944 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
